Question about Sony BRAVIA KDL-40V3000 Television
SOURCE: Tv cuts off and green light flashes
If your set was manufactured around July 2005, you may need a firmware upgrade to solve this issue. On the Sony website you can enter your model # and serial # to see if you TV is affected. If so, it is easy to have done and may be free from Sony. It sounds like the issue they described in the writeup on the required formware update. I had mine done within few months of when i bought it (purchased in Dec 2005) and it has been working flawlessly since.
Donnieboy999
Posted on Oct 21, 2008
SOURCE: tv immediately turns off
Four flashes indicates a problem with the backlight on the TV. It can be caused by the backlight inverter board (the power supply for the backlight) or by defective backlights in the panel It is USUALLY the backlight inverter board that is bad, but I have seen both components fail at various times. This set is fairly new and should still be withing the one year warranty, so you should contact Sony at 800-222-SONY to get it repaired. Be sure to rate this solution. Thanks!
Posted on Nov 17, 2008
Your lamp is getting dim. You need a new one.
Posted on May 11, 2009
SOURCE: Picture & sound suddenly shut off. power light blinks red 5X...5X
http://www.sonya20tvclassaction.com/main/home.sfx MAKE SONY FIX IT
Posted on Dec 03, 2009
Oct 29, 2012 | Mitsubishi WS-55511 55" Rear Projection...
Aug 09, 2011 | Mitsubishi WS-65807 65" Rear Projection...
Jul 15, 2011 | Mitsubishi WS-55819 55" Rear Projection...
Jun 09, 2011 | Mitsubishi WS-65315 65" Rear Projection...
Sep 14, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Jun 24, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Dec 11, 2009 | Mitsubishi WS-65311 65" Rear Projection...
Aug 14, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Feb 09, 2009 | Sony KP-43T90 43" Rear Projection...
Jan 13, 2008 | Sony KP-41T65 41" Rear Projection...
