I need the direct entry code to program my tv with this remote
NECESITO HOJA ADJUNTA DE CODIGOS DEL RM24911 POR FAVOR
Hi can you tell me what are the romote codes, to program a ge tv using a ge universal control model rm24911. thank you
After much searching and aggravation - i found it! enjoy :)
http://www.eliztech.com/remotes/ge-4digit-tv-codes.php
Http://www.jascoproducts.com/support/universal-Remote-codes.asp
this is the site for ge codes
To program your universal remote to control your components
using the Direct Code Entry Method, follow the steps below.
1* Manually turn on the component
you want the remote to control.
2* Locate the enclosed Code Lists.
Find the list for the component you
wish to program. Find your
component's brand. You will see a
listing of four-digit codes for each
brand. If your brand isn't listed, use
one of the Code Search methods to
program the remote control. (Refer
to pages 7 and 9 for Manual and
Auto Code Search methods.)
3* Press and hold the component key
(TV, VCR•DVD, SAT•CBL) you
wishto program. The illuminated
ON•OFF key turns on and
remains on. If you release the
component key at any time
during the Direct Code Entry
procedure, the illuminated
ON•OFF key blinks four times,
and the process is exited.
4* While holding down the
component key, consult the Code
Lists for the four-digit code that
corresponds to your component's
brand and use the number keys
(0-9) on the keypad to enter it.
While you are pressing the
numbers, the illuminated
ON•OFF key turns off.
5* After the fourth number is
entered, the illuminated ON•OFF
key turns on. At this time, release
the component key. If the
illuminated ON•OFF key turns
off, you have entered a valid code
and have followed the correct
procedure for Direct Code Entry.
If you enter a code number that is not
in the Code Lists or you do not follow
all of the steps for Direct Code Entry,
the illuminated ON•OFF key blinks
four times when the component key
is released. This is an indication that
a programming error has occurred.
In that case, repeat the Direct Code
Entry process from step 3.
OK.
Universal remote allow you to control multiple
electronic devices with a single remote. You can use the remote to work
your TV,DVD player, cable boxes and other devices from the comfort of
couch.Philips is a popular manufacturer of universal remotes.to program a
GE remote for SONY TV,you will either need to input the device
code or perform a code search
direct entry
first.turn on your TV manually. next.press down
and hold set-up on the remote.the red indicator light will stay
lit.after that.press the TV device button to let the remote know you
wish to program a television then.enter your device four digit codes on
the remote..GE list several codes for SONY television including 0002 0006 0007 0018 0107 0114 0310 0312 0502 0601 0704 0719 0803 0806 0810 0901 0911
..if your remote needs 3 digit codes remove only the
number zero in the beginning of the codes finally.test the remote to
ensure it works.with the turned on,press the channel button and see if
the TV responds..if it is work the remote programmed and you are done,if
it doesn't work try the different code......
IF THIS SOLUTION HELPS YOU PLEASE DON'T FORGET TO RATE MY ANSWER THANK YOU
I need to enter a code to program my remote but I lost the paper that tells you the codes. I am using a GE Universal Remote Control.
