The machine dosn't want to spin and it makes a noise .
Check and see what type detergent you are using. I bought regular liquid detergent and the machine began making noise during the spin cycle and the drum would not spin. I was informed that you have to use detergent that is labeled HE (High Efficiency). The regular liquid detergent will suds up during the wash cycle which then causes the drum to slip and not spin during the spin cycle. What you are hearing during the spin cycle is the drum slipping. Unplug your washer for 30 minutes and let it reset. This lets the suds dry out. Run a cycle with no spin to rinse out the drum. This should eliminate your problem. If you have clothes in the machine, run a cycle with no spin, just don’t add any more detergent. Then run the normal cycle with spin a second time with no detergent. I hope this cures your problem.
My Washer Wont Agitate with cloths in the washer and when it go's into spin cycle the drum can't speed up and you hear a rumbling sound like something is slipping. My Washer is A LG TROMM 3.5 Front loading wm2077cw
i have lg tromm model no. wd-10180 tp . wash tub does not working . all idication are working.
