SOURCE: Where to get LCD screen for panasonic TC-32LE60 TV ?
Hi there, the only close part you could get is the actual cabinet. the actual screen will have to be shipped by the manufacture itself. these screens are filled with a liquid that is dangerous and has to be installed in a OSHA approved shop.
SOURCE: i have a panasonic tc-l32s1 lcd tv. when u power
The TV may have gone into shutdown mode because it may have sensed overvoltage or overcurrent due to short circuits.
You will have to open it up do some inspection inside the TV.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
SOURCE: attaching a bose cinemate to
Hi you can get the manual to set up the bose to your tv on the link below.
http://www.bose.co.uk/GB/en/images/AM289245_00_Cinemate_ENGvo_tcm6-27482.pdf
Good Luck
SOURCE: My panasonic lcd tv tc-L32x1.
I had a similar problem with my 42 in Philips LCD HDTV. Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of course) and found four bulged capacitors on the PSB. Many major electronics companies Philips/Magnavox, Sony, Panasonic, and others were sold capacitors that failed in 2-5 years instead of 10-20. The capacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in all sorts of devices and cause a wide range of failure problems. Here are some options for you. 1. Have it fixed by a professional $$$$$$$??????? (Is it under warranty?) Remember, TVs CONTAIN HIGH VOLTAGE AND CAN KILL YOU! Do this at your own risk. 2. Open your TV and find PSB. (The board that the power cord plugs into) Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board. The entire board costs around $250 right now because they are in high demand right now. They can be found online. I would definitely shop around though. 3. Remove and then replace individual faulty caps. This takes some soldering skill. Caps are inexpensive and if you can take care of it yourself it will save you hundreds. This may be your problem. If you determine that it might be. I have a Tip/How TO tutorial on this site that may also help. It gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. Here is the Link: Fixing the Philips Turns/shuts off on its own problem. I'm working on uploading pictures to help guide people though the process as well. Let me know if I can do anything to help. Hope this helps and if it does please rate it accordingly. Good luck.
SOURCE: Panasonic TC-32LX60C LCD TV Internal Speakers have
Please check in the Menu under Audio section if you can disable the internal speakers. In the Sony and Samsung TV's you can. It will be in the bottom of the of the audio scroll Menu.
It will ask you TV sound Internal / External ?
Choose internal
