2002 Dodge Durango Logo
Posted on Apr 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Odor coming from front door jams after shutting car door
I have been struggling with a strong mildew/mold odor whenever I shut the car door.  I comes out like a plume, and makes the area by the door and front tire smell very strongly like mildew.  Last night we were in Costco and happened to walk by a fertilizer/plant food display, and it smelled JUST LIKE what I smell from the car.  My husband has washed down the engine, we've sprayed the air vents inside and out with Smells Be Gone, and now he's taking off the door panel.  So far there is nothing in the panel that we can see.  Maybe it's in the doors???  I am going crazy because the smell makes me ill, and comes and goes.  HELP!!
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 01, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
538
Points
I have the same problem in my 2011 sonata and i finally figured out where its coming from, its inside the doors! Put your window down and then smell the top of the door where the window slides down in...its so gross....its been making me sick to my stomach!
Anonymous
Level 1:
  • Posted on Aug 20, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
538
Points
It is in your AC drain line. The drain line may become clogged or develop mildew from the condensation that develops running an AC...just like your home AC. when the fan or AC is running it will blow the smell out of the vents. You need to have the lines cleaned and flushed
kirtec auto
Level 3:
President:
  • Dodge Master 1,348 Answers
  • Posted on May 14, 2009
kirtec auto
Dodge Master
Level 3:
President:
Answers
1348
Questions
0
Helped
595990
Points
4360
Small rodents crawl up into the fender areas .i would put it on a hoist and have a really good look
Why ac odor?
The most common cause is the evaporator compartment needs to be cleaned because it can get moldy and dirty. Especially if the drain gets plugged and doesnt let the condensation out.
With the key off the dash lights stay on but when you open the door the go off but if you shut it again they come back on
With the door left open, open and close the door on the opposite side. If it works correctly, then you have a bad "door switch" (that little button mounted on either the front or rear jam pillar) on the "problem door" side.
1helpful
Kia sephia ac odor
It is mold and mildew, you must have an AC repair shop of the dealer do a special service with very toxic chemicals to kill the car infections,.
1helpful
I smell gas fumes and I'm not sure where its coming from.
It's possible that you have a fuel line or injector leaking on the engine. With the engine OFF take a look near the front center of the top of the engine by the fuel lines and injectors for any dampness or strong odors. I have seen a few leaks in this area and usually you'll catch a whiff of raw gas inside the vehicle as you sit in traffic or when you walk by the vehicle after shutting it off. Because of the risk of fire you should have this smell checked out as soon as possible.Good luck, hope this helps!
1helpful
My 200o expedition has a mildew type smeel when th a/c is on and its very strong what is going on
It is possible the drain on your heater box is plugged and not letting all the condensation out. Get a can of Lysol disinfectant and with the a/c on high and spray the Lysol at the base of the windshield on the passenger side cowl vent ( this is where the fresh outside air is picked up ) With the windows open you will be able to smell it coming through the vents. This will kill any bacteria or mold in the heater box and remove the odor. You can buy the pricey stuff from a parts store for this but I don't find it works any better than regular old original Lysol.
Hope this helps.
2helpful
Mildew odor / smell
You didn't state if you used your A/C often but that is the most likely source. If you use your A/C on maximum it does not allow any fresh air in the vehicle and just recycles the air over and over this allows for bacteria and mold in the system even though you don't see it. run your A/C on min. or medium for a few days this should clear up your problem.
1helpful
Odor coming from the heating AC system on a 99 300 M
Mold and mildew builds up in the system from moisture in the air, dealers have chemicals they spray inside the ducting to kill these molds and mildews, the service runs about $100, there is no permanent fix, this will need to be done from time to time as req'ed, a short term fix is to spray Lysol into the heating/AC air inlet at the base of the windshield, run the blower on high and set to outside air, spray in about 1/2 can and then turn of the system and let it set.
Top Dodge Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Dodge Expert? Answer questions, earn points and help others
