GMC Denali 700C Road Bike Logo
Posted on Apr 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My back brakes do not retract open after compressing them and the brake cable is not taught with the lever.
clay
Level 2:
  • Expert 74 Answers
  • Posted on Apr 13, 2009
clay
Expert
Level 2:
Answers
74
Questions
0
Helped
56811
Points
179
More then likely it is just a lubrication issue. Cables and housings need to be lubricated when they malfunction as such. Just a touch of lightwieght oil in the housing will work wonders. Also try lubricating all pivot points on the actual brake arms themselves.
Remember to use a bike specific lub and dont get any on the contacting surfaces of the brake pads......not a good thing at all.
1helpful
Instructions and diagram,to remove and replace rear drum brakes
1984 Ford Tempo - Rear Drum brake drum/shoes
REMOVAL & INSTALLATION
See Figures below instructions
1. Raise and safely support the vehicle with jackstands.
2. Remove the wheel, tire, hub and finally, the drum assembly.
3. Using a spring removal tool, remove the horizontal securing spring at the top first of the assembly.
4. Pull the adjuster locking plate away from the shoes.
5. Remove the lower horizontal securing spring.
6. Unfasten one of the 2 shoe hold-down springs and remove the pin.
7. Remove the brake adjuster.
8. Remove the remaining hold down spring and clip.
9. Lift the brake shoes assembly off the backing plate and wheel cylinder assembly. Be careful not to bend adjusting lever during the removal process.
10. Remove the parking brake cable from the parking brake lever.
11. Remove the horseshoe retaining clip and spring washer and slide the lever off the parking brake lever pin on the trailing shoe.
To install:
12. Apply a light coating of high temperature grease at the points where the brake shoes contact the backing plate.
13. Apply a light coating of lubricant to the adjuster screw threads and the socket end of the adjusting screw. Turn the adjusting screw into the adjusting pivot nut to the limit of the threads and then back-off 1 / 2 turn.
14. Assemble the parking brake lever to the trailing shoe by installing the spring washer and a new horseshoe retaining clip. Crimp the clip until it retains the lever to the shoe securely.
15. Attach the parking brake cable to the parking brake lever.
16. Attach the lower retracting spring to the leading and trailing shoe assemblies and install to backing plate. It will be necessary to stretch the retracting spring as the shoes are installed downward over the anchor plate to inside of shoe retaining plate.
17. Install the adjuster screw assembly between the leading shoe slot and the slot in the trailing shoe and parking brake lever. The adjuster socket end slot must fit into the trailing shoe and parking brake lever.
The adjuster socket blade is marked R or L for the right or left brake assemblies. The R or L adjuster blade must be installed with the letter R or L in the upright position, facing the wheel cylinder, on the correct side to ensure that the deeper of the 2 slots in the adjuster sockets fits into the parking brake lever.
18. Assemble the adjuster lever in the groove located in the parking brake lever pin and into the slot of the adjuster socket that fits into the trailing shoe web.
19. Attach the upper retracting spring to the leading shoe slot. Using a suitable spring tool, stretch the other end of the spring into the notch on the adjuster lever. If the adjuster lever does not contact the star wheel after installing the spring, it is possible that the adjuster socket is installed incorrectly.
20. Inspect your work to make sure it is correct.
21. Install the hub/drum and wheel/tire assemblies and adjust the wheel bearings.
22. Lower the vehicle and check brake operation.
Fig.1 Exploded View of Rear Brakes - 1984 Ford Tempo
Fig 2. Remove the brake shoe upper retaining spring with a suitable removal tool.
Fig.3 Removed retaining spring - note spring direction.
Fig.4 Remove the adjuster lock plate. Note the direction of the tab.
Fig.5 Remove the lower retaining spring.
Fig.6 Remove the Hold Down Spring - note brake spring tool used.
Fig.7 remove the shoe adjuster. Note direction of the adjuster spline.
Fig.8 Remove the hand brake cable.
Fig.9 Remove the final brake shoe.
Fig.10 All removed parts in order and properly oriented for re-assembly.
Diagram for parking brake cables
Removal & Installation
  1. For the 1500HD, relieve the tension from the park brake cable by pulling down on the park brake cable in front of the equalizer then removing the cable from the equalizer bar.
  2. For the 25/35 series Disable the park brake cable automatic adjuster.
  3. Raise and safely support the vehicle.
  4. Remove the tire and the wheel.
  5. Perform the following procedure to remove the cable (2) from the backing plate (4):
    • Compress the spring (3) by pushing toward the lever (1).
    • Depress the locking tabs.
    • Pull the cable housing out of the backing plate (4).
    • Remove the cable (2) through the slot in the backing plate.
      Lever (1), cable (2), spring (3) and backing plate (4)
  6. Remove the park brake cable (2) from the lever (1).
  7. Remove the rotor.
  8. Remove the rear axle shaft.
  9. Remove the park brake shoe return spring (6).
    Park brake shoe assembly 1500HD, 25 and 35 Series
    Click to Enlarge
  10. Remove the park brake shoe anchor springs and pins.
  11. Separate the tips of the shoes from the park brake actuator and remove the park brake shoes and adjuster assembly from the vehicle.
To install:
  1. Clean the debris and the dust from the park brake components using a clean shop cloth.
  2. Install the adjuster assembly to the park brake shoes.
  3. Separate the tips of the shoes and install the park brake shoes to the park brake actuator.
  4. Install the park brake shoe anchor springs and pins.
  5. Install the park brake shoe return spring (6).
  6. Adjust the park brake shoe.
  7. Install the rear axle shaft.
  8. Install the rotor.
  9. Install the park brake cable (2) to the lever (1).
  10. Perform the following procedure to install the cable (2) to the backing plate (4):
    • Compress the spring (3) by pushing towards the lever (1).
    • Route the cable (2) through the slot in the backing plate.
    • Push the cable housing into the backing plate (4) until the locking tabs snap into place.
  11. Install the tire and wheel.
  12. Remove the safety stands.
  13. Lower the vehicle.
  14. Enable the park brake cable automatic adjuster.
  15. For the 1500HD, install the park brake cable to the equalizer by pulling down on the park brake cable in front of the equalizer then installing the cable to the equalizer bar.
  16. Adjust the park brake cable.
// // 0) preLoad.src = ctl00_cphLeft_chRepairTreeNav_tvTOC_ImageArray[i]; } ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.lastIndex = 23; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.populateLog = theForm.elements['ctl00_cphLeft_chRepairTreeNav_tvTOC_PopulateLog']; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.treeViewID = 'ctl00$cphLeft$chRepairTreeNav$tvTOC'; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.name = 'ctl00_cphLeft_chRepairTreeNav_tvTOC_Data'; //]]> var _strTreeScrollHidName = 'ctl00_hidTreeScrollPos'; shinehutt_0.gif
Remove replace rear brakes on ford t bird 1996
1989-97 Vehicles Drum Brakes (Let me know if you need the Disc Brake Instructions)
  1. Raise and safely support the vehicle.
  2. Remove the rear wheel and tire assemblies, then remove the brake drum.
    Fig. 4: View of the drum brake assembly with the drum removed
    Fig. 5: Use a commercially available brake spray to clean the
    components before removal
  3. Install Brake Cylinder Clamp D81L-1103-B or equivalent, over the ends of the
    rear wheel cylinder.
  4. Disconnect the parking brake cable from the parking brake lever.
    Fig. 6: Detach the parking brake cable and conduit from the
    parking brake lever
  5. Remove the 2 brake shoe hold-down retainers, springs and pins.
  6. Spread the brake shoes over the piston shoe guide slots. Lift the brake
    shoes, springs and adjuster off the backing plate as an assembly. Be careful not
    to bend the adjusting lever.
    Fig. 7: Lift the brake shoes, springs and adjuster off the
  7. Remove the adjuster spring. To separate the shoes, remove the retracting
    springs.
  8. Remove the parking brake lever retaining clip and spring washer. Remove the
    lever from the pin.
    Fig. 8: Drum brake components - 1995 vehicle shown
    Fig. 9: Exploded view of the drum brake components, removed
    from the vehicle
    To install:
  9. Apply a light coating of caliper slide grease to the backing plate brake
    shoe contact areas.
  10. Apply a light coat of lubricant to the threaded areas of the adjuster screw
    and socket. Assemble the brake adjuster with the stainless steel washer. Turn
    the socket all the way down on the screw, then back off 1?2 turn.
  11. Install the parking brake lever to the trailing shoe with the spring washer
    and a new retaining clip. Crimp the clip to securely retain the lever.
  12. Position the trailing shoe on the backing plate and attach the parking brake
    cable. Position the leading shoe on the backing plate and attach the lower
    retracting spring to the brake shoes.
  13. Install the adjuster assembly to the slots in the brake shoes. The socket
    end must fit into the wider slot in the leading shoe. The slot in the adjuster
    nut must fit into the slots in the trailing shoe and parking brake lever.
    Fig. 10: Install the adjuster assembly in the slots in the
    brake shoes
  14. Install the adjuster lever on the pin on the leading shoe and to the slot in
    the adjuster socket.
  15. Install the upper retracting spring in the slot on the trailing shoe and the
    slot in the adjuster lever. The adjuster lever should contact the star and
    adjuster assembly.
  16. Install the brake shoe anchor pins, springs and retainers. Remove the brake
    cylinder clamp tool
  17. Install the brake drum, wheel and tire assemblies and lower the vehicle.
  18. Apply the brakes several times while backing up the vehicle. After each
    stop, the vehicle must be moved forward.
How to installing brake shoes on back ?
First you have to compress the parking brake cable spring and attach the parking brake lever.
Clean and lubricate the brake backing plate.
Use silicon Brake Caliper Grease and Dielectric Compound.
Then,
install the rear brake shoes and linings:
1) position the rear brake shoes and linings
2) position the parking brake lever
3) install the brake shoe hold-down spring pins and the brake shoe hold-down springs.
Install the parking brake strut
1. install the parkig brake link spring on the parking brake strut
2. install the parking brake strut
3. Install the brake shoe anchor ping guide plate.
Install the short brake shoe retracting spring
1. Place the brake shoe adjusting lever cable over the anchor pin, with crimped side in
2. Install the short brake shoe retracting spring
Note: Make sure the brake shoe adjusting lever cable is positioned in the cable guide groove
Install the long brake shoe retracting
1. install the cable guide
2. position the brake shoe adjusting lever cable in the cable guide groove
3. install the long brake shoe retracting spring
Note: to prevent incorrect installation, teh socket of each brake adjuster screw is stamped R or L
Assemble the brake adjuster screw assembly.
1. apply silicone brake caliper grease and dielectric compound
2. install the brake adjuster screw into the brake show adjusting screw nut to the end of the threads and then loosen one half turn
3. install the brake shoe adjusting screw socket on the brake shoe adjusting screw nut.
Install the brake adjuster screw assembly
1. Position the brake adjuster screw assembly
2. Install the brake shoe adjusting screw spring
3. Position the brake shoe adjusting lever cable
4. Position the adjusting lever return spring and the brake shoe adjusting lever
5. Hook the brake shoe adjusting lever cable to the brake shoe adjusting lever.
Test the operation of the automatic self-adjuster
1. Pull the brake shoe adjusting lever cable and check that the brake shoe adjusting lever rotates the brake shoe adjuster assembly
2. Release the brake shoe adjusting lever cable and check that the brake shoe adjusting lever advances to the next notch on the brake shoe adjusting screw nut.
Adjust the brakes.
Install the brake drum.
Thats it
Diagram for back brakes on a 1995 jeep cherokee sport
Brake Shoes REMOVAL & INSTALLATION Fig. 1: Use a brake cleaner to clean the brake surfaces 86749p23.jpg
Fig. 2: Using a brake tool, remove the return spring from the anchor pin 86749p24.jpg
Fig. 3: Remove the return spring and the adjuster cable guide 86749p25.jpg
Fig. 4: Remove the adjuster cable 86749p26.jpg
Fig. 5: Remove the shoe guide plate 86749p27.jpg
Fig. 6: Disengage the hold-down spring retainers from the hold-down pins 86749p28.jpg
Fig. 7: Remove the hold-down springs and pins 86749p29.jpg
Fig. 8: Pull the shoes apart and then . . . 86749p30.jpg
Fig. 9: . . . remove the parking brake strut and spring 86749p31.jpg
Fig. 10: Remove the shoes from the backing plate 86749p32.jpg
Fig. 11: Disengage the parking brake cable 86749p33.jpg
Fig. 12: Lubricate the shoe contact points — 10 inch drum brake backing plate shown 86749g41.gif
Fig. 13: Adjusting the gauge to fit the brake drum 86749g42.gif
Fig. 14: Adjust the brake shoes to fit the gauge 86749g43.gif
Fig. 15: Adjusting the drum brakes using a brake spoon 86749p35.jpg
CAUTION
Brake shoes may contain asbestos, which has been determined to be a cancer causing agent. Never clean the brake surfaces with compressed air! Avoid inhaling any dust from any brake surface! When cleaning brake surfaces, use a commercially available brake cleaning fluid. NOTE: A brake spring removal tool and a brake adjusting gauge are required for this procedure.
  1. Raise and support the vehicle safely with jackstands.
  2. If the brakes have never been serviced before, the drums will be held on the wheel studs with spring nuts. Remove the spring nuts and discard.
  3. Turn the adjustment starwheel so that the brake shoes are retracted from the brake drum and remove the brake drum.
  4. Install wheel cylinder clamps to retain the wheel cylinder pistons in place and prevent leakage of brake fluid while replacing the shoes.
  5. Remove the U-clip and washer securing the adjuster cable to the parking brake lever.
  6. Remove the adjuster cable, cable guide, adjuster lever and adjuster springs. Remove the return springs with a brake spring remover tool.
  7. Remove the hold-down retainers and springs, then remove the brake shoes. To install:
  8. Clean the backing plate with a brush or cloth. Place a dab of Lubriplate® on each spot where the brake shoes rub on the backing plate. NOTE: Always replace brake linings in axle sets. Never replace linings on one side or just on one wheel.
  9. Thoroughly clean and lubricate the adjuster cable guides, adjuster screw and pivot, parking brake lever and lever pivot pin with multi-purpose grease.
  10. Apply a thin coat of multi-purpose chassis lube to the mounting pads on the backing plate.
  11. Transfer the parking brake actuating lever to the new secondary shoe.
  12. Position the brake shoes on the backing plate, then install the hold-down springs and retainers. Don't forget to engage the parking brake lever with the cable.
  13. Install the parking brake actuating bar and spring between the parking brake lever and primary shoe.
  14. Install the self-adjusting cable, cable guide and upper return springs.
  15. Thoroughly clean the starwheel and lightly lubricate the threads with lithium based grease.
  16. Install the starwheel.
  17. Install the self-adjusting cam and lower spring. A big pair of locking pliers is good for this job.
  18. Check the surface of the brake shoes for any grease that may have gotten on them. If dirty, lightly clean with a piece of sandpaper.
  19. Adjust the brakes, install the brake drum and wheel. Lower the vehicle and test drive.
1helpful
2answers
1997 Ford contour rear brake shoe replacment help.
Brake shoe removel:
Depress and turn the retainers for the hold-down springs and pins to remove them from each shoe. Slide the brake shoe assembly--including the shoes and springs--down so you can disengage the top ends of the shoes from the cylinder and tilt them to lift them past the retaining plate.
Unhook the lower retracting spring from the front brake shoe to disconnect it. Spread the shoes apart at the bottom to remove the adjusting screw, the screw's retracting spring and the adjuster lever. Remove the front brake shoe.
Pull the parking brake cable spring back with diagonal cutting pliers, grip the cable with the pliers without cutting it, unhook the cable from the parking brake lever and remove the rear brake shoe with the lever.
Disconnect the parking brake lever from the rear shoe by spreading the retaining clip with a screwdriver and removing the clip and its spring washer.
  • Step 4 Pull the parking brake cable spring back with diagonal cutting pliers, grip the cable with the pliers without cutting it, unhook the cable from the parking brake lever and remove the rear brake shoe with the lever.
  • Step 5 Disconnect the parking brake lever from the rear shoe by spreading the retaining clip with a screwdriver and removing the clip and its spring washer.
  • Read more: How to Change Rear Brakes on a 1997 Ford Taurus | eHow.com http://www.ehow.com/how_6123373_change-brakes-1997-ford-taurus.html#ixzz0u2xgUqun
  • Step 3 Unhook the lower retracting spring from the front brake shoe to disconnect it. Spread the shoes apart at the bottom to remove the adjusting screw, the screw's retracting spring and the adjuster lever. Remove the front brake shoe.
  • Read more: How to Change Rear Brakes on a 1997 Ford Taurus | eHow.com http://www.ehow.com/how_6123373_change-brakes-1997-ford-taurus.html#ixzz0u2xdByQ8
  • Step 2 Slide the brake shoe assembly--including the shoes and springs--down so you can disengage the top ends of the shoes from the cylinder and tilt them to lift them past the retaining plate.
  • Read more: How to Change Rear Brakes on a 1997 Ford Taurus | eHow.com http://www.ehow.com/how_6123373_change-brakes-1997-ford-taurus.html#ixzz0u2xVyUAt
    5helpful
    My roommate borrowed my bike and brought it back broken. Then brakes do not work - I know nothing about repairing them. Part of the brakes - the cable that goes to the right side is hanging to the ground....
    if the knob is still on the end of that brake cable, then you just need to tighten your rear brakes by squeezing on them and pull the cable taught... you should then be able to just slide the cable into a lil groove on the handle lever and slip the knob back into the hold on the bottom of the handle lever
    1helpful
    1999 nissan quest rear brake shoes need changing
    help is here:
    http://autos.groups.yahoo.com/group/villagerquest/
    Drum Removal
    1. Remove the rear wheel and the tire assembly. Refer to Section 204-04 .
    1. Retract the brake shoes and loosen the brake adjuster screw.
    1. Remove the brake drum.
    May require big hammer to loosen drum from axle flange. Hit between the the lugs, not on them.
    #10 is access plug to back off adjusting wheel.
    Item Part Number Description 1 2261 Rear wheel cylinder 2 — Dust boot (part of 2128) 3 2197 Wheel cylinder piston (part of 2261) 4 — Cup (part of 2128) 5 2204 Wheel cylinder piston cup spring (part of 2128) 6 — Wheel cylinder housing (part of 2261) 7 — Brake shoe hold-down pin 8 — Access hole (part of 2212) 9 — Rear brake bleeder screw (part of 2261) 10 — Access hole plug 11 — Rear wheel cylinder bolt 12 2212 Rear brake backing plate 13 — Rear brake backing plate bolts 14 2N790 Parking brake lever clip 15 — Spring washer 16 — Secondary brake shoe and lining (part of 2200) 17 — Brake shoe hold-down spring (part of 2B514) 18 — Lower retracting spring (part of 2B514) 19 2A637 Parking brake lever 20 — Parking brake lever pin 21 2A177 Brake shoe adjusting lever 22 — Adjuster lever pin (part of 2A177) 23 — Primary brake shoe and lining (part of 2200) 24 — Upper retracting spring (part of 2B514) 25 2041 Brake adjuster screw
    Shoes Removal
    Take a picture and remember how each part goes and attaches
    1. Remove the brake drum, refer to Drum in this section.
    1. Remove the upper retracting spring.
    1. Remove the lower retracting spring.
    1. Remove the self-adjuster.
    1. Remove the hold-down springs.
    1. Remove the parking brake lever clip and the parking brake lever.
    2helpful
    I need a schematic for the rear brakes on an F150 super cab with 4.6L automatic trans 4wheel drive
    Drum, Rear Brake System Standard Rear Brake
    Item Part Number Description 1 2069 Brake Shoe Hold-Down Spring Pin 2 — Rear Wheel Cylinder Retaining Bolt (2 Req'd) 3 — Washer (2 Req'd) 4 — Anchor Pin (Part of 2211) 5 — Wheel Cylinder 6 2028 Brake Shoe Anchor Pin Guide Plate 7 2A637 Parking Brake Lever 8 2296 Brake Shoe Retracting Spring (Short) 9 2296 Brake Shoe Retracting Spring (Long) 10 2200 Rear Brake Shoe and Lining (Secondary) 11 — Washer 12 2106 Parking Brake Lever Pin Retainer 13 — Brake Shoe Adjusting Lever Cable Guide 14 2A642 Primary Brake Shoe Parking Brake Lever Link 15 2A601 Parking Brake Link Spring 16 2068 Brake Shoe Hold-Down Spring 17 2A176 Brake Shoe Adjusting Lever 18 2048 Brake Shoe Adjusting Screw Socket 19 2047 Brake Shoe Adjusting Screw Nut 20 2041 Brake Adjusting Screw 21 2049 Brake Shoe Adjusting Screw Spring 22 2200 Rear Brake Shoe and Lining (Primary) 23 2A178 Brake Shoe Adjusting Lever Cable 24 2211 Brake Backing Plate
    Heavy Duty Rear Brake
    Item Part Number Description 1 — Rear Wheel Cylinder Retaining Bolt 2 00538 Lock Nut 3 2212 Rear Brake Backing Plate 4 2262 Rear Wheel Cylinder 5 2A642 Primary Brake Shoe Parking Brake Lever Link 6 2A601 Parking Brake Link Spring 7 2A637 Parking Brake Lever 8 2106 Parking Brake Lever Pin Retainer 9 — Parking Brake Lever Bolt 10 — Secondary Shoe Assembly 11 2A179 Brake Shoe Adjusting Lever Cable Guide 12 2068 Brake Shoe Hold-Down Spring 13 — Adjusting Lever Pin 14 — Adjusting Lever Return Spring 15 2A176 Brake Shoe Adjusting Lever 16 2047 Brake Shoe Adjusting Screw Nut 17 2049 Brake Shoe Adjusting Screw Spring 18 2041 Brake Adjuster Screw 19 — Primary Shoe Assembly 20 2068 Brake Shoe Hold-Down Spring 21 2200 Rear Brake Shoe and Lining 22 2035 Brake Shoe Retracting Spring 23 2A178 Brake Shoe Adjusting Lever Cable 24 2092 Brake Adjusting Hole Cover 25 2069 Brake Shoe Hold-Down Spring Pin
    The rear drum brakes:
    • Have internal shoes that expand against the brake drum (1126).
    • Are a single-anchor type.
    • Are actuated by one rear wheel cylinder (2262).
    • Have two pistons in the rear wheel cylinder (2261). One exerts force against the upper end of the primary shoe; the other exerts force against the upper end of the secondary shoe.
    • Adjust rear brake shoes and linings (2200) automatically.
    • Need manual brake adjustment if the adjusters are not operating properly or after the rear brake shoes and linings have been replaced.
    When the brake pedal is applied, hydraulic fluid pressure forces the pistons in the rear wheel cylinder outward, moving the rear brake shoes and linings against the brake drum.
    The rear drum brake system includes the parking brake mechanism. Refer to Section 206-05 .
    Top GMC Cycling Experts
    ADMIN Andrew
    ADMIN Andrew
    Kardoc
    Tony Parsons
    Tony Parsons
    Are you a GMC Cycling Expert? Answer questions, earn points and help others
