Mitsubishi WD-52531 Television Logo
Anonymous Posted on Aug 28, 2013
Ant get hdmi to work - Mitsubishi WD-52531 Television
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Aug 28, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
228
Points
27
Try unplugging it and then plugging it back in.
MY BOX KEEPS SAYING BOOT DID i CONNECT SOMETHING WRONG
Antenna cable would go into ANT in
What cable did you use to connect box to tv.
I don't have the user manual so I am guessing that ANT out is for analogue channels 3 and 4 to go through to the tv. think
I suspect the coaxial out would go out to a video in type connection on the television.
If the Television has HDMI inputs I
you should go out and buy a HDMI cable and use HDMI out on the box.
Does the remote control for the box have a plastic strip in the battery compartment that stops the batteries. Or are batteries in the battery compartment.?
1helpful
3answers
I have a wd-62525 dlp i have pic and sound through ant. and hdmi but on component and video inputs i only get sound no pic
Hello
It seems to be some fault with its HDMI cable you connect to this device from the source. As you get sound by HDMI, and no picture at all, this indicates the fault with cable itself. There is a cution notice says that " To assure continued FCC compliance, the user must use a shielded video interface cable
with bonded ferrite cores at both ends, when using the PC or HDMI input."
Cheang the cable and check.
1helpful
1helpful
We cannot get our hdb841 to tune into our awa hd
Hi! I believe you have some concern on how to get good picture on your hd tv. I will be more than glad to assist u.. on your teac hdb841- there is a port connection - ant in, you have to connect the ant cable from your off the air tv antena to the ANT IN of the Teac HDB841. then on the back of your Teac HDB841, you have several output connection there like component, coax, s-video, rca and hdmi. since u have the hdtv u need to use the hdmi or the component cable whiich is the red blue and green then access the menu of the teac hdb841 and do a scan for the local channels.. ur tv should tune in to hdmi if u use hdmi cable or component if u use the red blue and green.. i hope this will fix the problem..
Hdmi not working
Please rephrase you get an "ant screen"?
Does the sound work? What is your hdmi video output device?
At any rate, you can also try this quick fix. In the setup menu go to Source Select. Make sure these settngs are right:
Assign>HDMI = HDMI 1 - 4 (depending on device)
Input Mode>Input Mode = Auto
Decod Mode>Decode Moe = Auto
Other>Video Convert = On
Set this for sources (devices) you have connected to the hdmi.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
