Samsung HLN467W 46" Rear Projection HDTV Logo
Posted on Apr 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Samsung HLN467W Flashing "LAMP" LED
Light went out with all three indicator ilghts flashing; replaced the lamp, worked for about 30 secs, then went out. Tried again after cleaning dust, etc; lasted about 2 minutes. Now just get flashing middle light; cycles; sounds like capacitor charging; ten stops; starts process again. Curiously, have to unplug TV to turn off...
  • 6 more comments
  • pfkirkstum Apr 11, 2009
    Is it fairly obvious where to check voltage of power supply to ballast upon opening back of TV? I assume TV has to be turned on (obviously!) which means little blue switch on lamp door has to be taped down or held down somehow...
  • pfkirkstum Apr 12, 2009
    I don't think this is the ballast; can hear the whining as it tries to power up, no clicking as described by others. Will replace anyhow if nothing else turns up. How does one check power supply?
    I thought of this, and replaced the origianl lamp (which I now suspect is not the problem) and the same thing happens.
    Fans run fine. I bought online the repair manual and two of the possible causes are the ballast and power supply; power supply supposed to be 300 v, so I guess I'll have to go in and check this too
    I unplugged power plug to ballast and measured voltage to ballast as 385 v; higher than 300 specified. Is this a problem? I'll try to email manual. Also heard same capacitor like sound without power to ballast, so maybe is ballast...
    Is there any significance to the voltage having measured 385v?
    If not, I'll just order ballast and see how it goes.
    thanks!
Anonymous
Level 3:
  • Master 10,594 Answers
  • Posted on Apr 12, 2009
Anonymous
Master
Level 3:
Answers
10594
Questions
9
Helped
2957066
Points
33084
Are you sure you replaced correct Samsung original lamp and it is not aftermarket or cheap one?
  • 4 more comments
  • Anonymous Apr 12, 2009
    Please check fans are running properly?
    If ballast supply fails, TV will not power up.
    If any fan stop running, may be a wire got stuck there, TV will not power up.
    OK,
    You should check all output voltages in power supply as per service manual.
    I do not have that particular model schematics so if you could email service manual to [email protected] then I would be in better position to help you out.
    Yes, as lamp is new and fans are running so Ballast supply is only thing that can be bad.
    It is available in Part Store.
    I'm waiting service manual in email to look its schematics.
    Thanks.
    Thank you for sending service manual.
    Part number of ballast supply is AA4700008A and available in Part Store.
    If you measure voltage without ballast supply attached then it would be greater then normal reading like 300V DC can be around 350V DC or so.
    Please check manual page 9-5 ( page 48 in reader bar) It is mentioned that Ballast supply input is 380V from main power supply board. Image is appended below...
Anonymous
Level 2:
Sergeant:
  • Expert 431 Answers
  • Posted on Apr 11, 2009
Anonymous
Expert
Level 2:
Sergeant:
Answers
431
Questions
Helped
95840
Points
987
Remove the lamp and visually check if inside looks broken.if visually do not see any thing wrong,check if you have 300 volts dc supply on the ballast which starts the lamp.if you do then the ballast may be defective.if you do not then the power supply should be checked.
the lamp should always be tried first especially if is older than two years.
note - be aware about the switch at the door lamp.the door should be closed,otherwise tv will not work.if you remove the back cover,make sure to bypass the switch temporarely so you could work on the set.
Anonymous
Level 2:
Sergeant:
  • Expert 254 Answers
Anonymous
Expert
Level 2:
Sergeant:
Answers
254
Questions
0
Helped
105247
Points
659
I got it.i will explain.
what exactly happens.as what the error you got is for lamp replacement.but if the lamp is new and after lamp replacement.if still the lights blink and the tv does not comes up that means its100% ballast problem.the ballast needs replacement.
it not at all any other fault.its ballast problem.
please do rate the solution
thank you for using fixya.
keep updated.
thanks.
Yellow blinking light . what does it mean
A blinking yellow for this model indicates the TV is too hot, unplug & allow 30-45 min to cool before re-plugging .
OR: lamp not installed or lamp door not closed. there is a lamp door switch that may not be closing, simulating door not closed
LED Indications
The front panel Status LED provides an indication of
the set's operation and the possible cause of a malfunction.
If an abnormal condition is indicated, perform the
Self Diagnostics procedure.
Self Diagnostics
To activate, press the front panel <ACTIVITY> &<CH
??> buttons at the same time and hold for 5 seconds.
The STATUS LED will then flash denoting a two digit
code.
• The number of flashes indicates the value of the
MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2
second.
• The LED then flashes indicating the value of the
(ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: If the Error Code is "23", the LED
will flash two times, pause, and then flash three
times.
Table 2-2: LED Indications
Error Codes, descriiptions and the most likely cause of
the error are listed in Table 2-3.
Note: The TV must be in "Shut Down." The LED
will probably be indicating an abnormal
condition. If the TV is switched Off, AC is
removed, or a System Reset is performed, the
code automatically resets to "12" No Error.
See the Error Code Log to retrieve a history of
errors.
Note: Use the front panel buttons, not the remote
control.
Note: If there is no response, the front panel may be
locked by a V-Chip setting. To unlock, press
and hold <ACTIVITY> on the front panel for
8 seconds.
LED Indication Condition
Off Off (standby)
Green Power On
Slow Blink Green Power Off with Timer Set
Fast Blink Green (80 seconds) > Off Power Off (Cooling fan still working, 80 sec)
Red Lamp Failure
Yellow TV Too Hot
Slow Blink Red TV May Require Service
Slow Blink Yellow Lamp Door Open or No Lamp Installed
NORMAL INDICATIONS
ABNORMAL INDICATIONS (For details perform Self Diagnostics Procedure.)
2answers
Samsung DLP HL-S5087W 56" Confused...
Those lamps can be pretty touchy and susceptible to temperature changes and finger prints. Also some discount lamp dealers can accidently sell you the wrong lamp. Something simple and dull to try is to take that lamp out and put it back in, check that the connections are seated properly and the air pathway from the fans is clear.  If the fans were dirty and you put in a new bulb that worked for a while it may have burned out prematurely.
I have been given a used Samsung TV without manual and have no idea how old it is or the exact size of this particular TV however, it is bigger than a 42''. I have written down the model code, serial...
The front panel LED light indication "LAMP" flashes?Change the the tv projection lamp or LED lamp first,see what happen?Than go from there?Tvs with "LAMP" LED indication light flashes,tv 1 1/2 or 2 years old use like 4 or 5 hours a day.The projection or LED lamp or bulb,inside life span is over.Require changing LED lamp or projection bulb.
The tv keeps turning itself on and off
Ur tv have a LED POWER indicator light and a LED light indicator LAMP flashing?Yes,this is a DLP Tv the lamp live is over,must be replaced it with a new lamp.No,LED light LAMP indicator flashing,than ur tv is a LCD or a Plama tv.Than ur power supply board is dead.Must replaced the power supply board to solved this problems.
1helpful
Lamp Light on the front is flashing green.
www.pdfee.com/.../Toshiba%20rear%20projection%20training%20manual - United States
www.pdfee.com/search/panasonic+rear+projection+tv - United States
www.scribd.com/.../Hitachi-Training-Manual-Projection-Television-DLP-1 -
Those links should help you understand what's going on. You need to get a service manual, like those supplied, but for your exact make and model.
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=02010300&prd_mdl_cd=&prd_mdl_name=HLN467W
1helpful
I just replace the lamp w/housing and color wheel on Samsung HLN467W--now the lamp light is flashing and the temp light is red, why?
Hello you may also have a bad thermal fuse which is located above or to the side of the lamp housing, IF you are getting 6 blinks and then pause for 3 secs then 6 again, the thermal fuse is open and needs to be replaced.
1helpful
Tv went off while watching a program power standby red light blinks 6 times then pauses then repeats tried unplugging unit waiting a few minutes then replugged same results nothing. can anyone help me ?...
Here's an excerpt from the Sony Manual online. And the link - http://esupport.sony.com/US/perl/webtree.pl?template=EN&mdl=KDF55XS955&content_id=68&category_id=11&problem_id=52
The POWER/STANDBY (red) indicator flashes three times
If your power/standby indicator is flashing in a pattern of three flashes, this may indicates that the lamp cover is not attached securely. Follow the directions in the Operating Manual under changing your lamp that related to closing and securing the Lamp Cover. Ensure that the Lamp Cover Door is securely fastened by tightening each screw.
The POWER/STANDBY (red) indicator flashes continously
If your power/standby indicator is flashing continuously, and the lamp cover has been secured, your TV may be in need of service.
The POWER/STANDBY indicator is lit up green (not flashing)
A sustained green light indicates your TV is on.
The POWER/STANDBY indicator is lit up red (not flashing)
A sustained red light from your power/standby indicator simply indicates that your TV is in standby mode. This shows you that your TV is ready to be turned on with the remote.
Is it the power light and not the lamp light? If the lamp light is flashing then replace the lamp.
2answers
remove the lamp and visually check if inside looks broken.if visually do not see any thing wrong,check if you have 300 volts dc supply on the ballast which starts the lamp.if you do then the ballast may be defective.if you do not then the power supply should be checked.
2helpful
Mine did that when the color wheel didn't spin up...just give it a whack where you installed the light & the wheel should spin up. I had to replace my color wheel as the bearing was shot & was buzzing all the time. The light won't come on if the wheel doesn't spin up first.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
