If the problem is not resolving read manual manual see if there is any guarantee ,if its not too old .
Sometimes take out wallconnector , a cannister of compressed air to clean something inside, If microswitches are used or an opto coupler , sometimes a new printer is cheaper then repair
A very little suggestion sometimes you have luck by Youtube without commercial costs.
Out of Paper Error Displays and the Printer Does Not Pick Paper in All in...
SOURCE: Flashing red light on display
1st step - print a self test report Press and hold the OK button. Then press the left arrow key one time. Release the OK button. The test page prints OR Press the OK and Help keys simultaneously. The test page prints print the test pages 4 time minimum 2nd step - reset the printer If the printer is not off, press the Power button to turn it off. Unplug the power cord from the wall outlet. Unplug the power cord from the back of the printer. Unplug the universal serial bus (USB) cable from the back of the printer, if connected. Wait 30 seconds, then plug the power cord back into the printer. Plug the power cord back into the wall outlet. Press the Power button to turn the printer on. Ensure that the memory card has been removed from the memory card slot. Make sure plain paper is loaded in the In Tray. Hold down the OK button and press the Right arrow button four times. If the test page prints, re-connect the USB cable to the printer. OR IF YOU ARE NOT ABLE TO DO SO THEN start - printers & faxes - click on the printer icon highlighted with a correct symbol ( ensure the proper printer is highlighted )- right click on the icon - properties - print test page option at the bottom of the properties screen. 3rd step - if the USB is connected to a USB Hub then disconnect it from the HUB and connect it directly to the wall socket.Make sure the USB cord is of the proper measurement as mentioned for the printer in the User Manual. 4th step - visit www.hp.com left side of the screen you shall see an option SOFTWARE & DRIVERS DOWNLOAD click on that in the next screen a tab comes up mentioning FOR PRODUCT enter PHOTOSMART D 5160 and hit enter / click on the arrow beside it choose the OS under DRIVER YOU HAVE OPTIONS LIKE - » HP Basic Driver (recommended) » HP Full Software and Driver (before downloading it uninstall the s/w & then download it )-DO THIS ONLY IF THE 1ST OPTION DOES NOT MAKE THE PRINTER FUNCTION FINE STILL ERROR PERSISTS : - replace if under warranty/service the printer in the service centre
SOURCE: Pixma ip1500 permanent paper jam-with video showing
the problem is with the software of your printer.. here's what you should do.. install back your printer, and then turn on your computer.. press ctrl + shift + escape.. this will open the task manager.. on the task manager, look for spool.exe and end its process... afterwards, try to reboot your computer.. i just hope this will work.. and please don't disassemble your printer again.... if this won't work, send your printer back to the manufacturer and they will have it fixed for you.. ok?
SOURCE: paper jam
Don't know if it's the same problem i had but its maybe worth a try. Canon MP160
My paper went in a little, the wheels were turning but it didn't take the rest of the paper or print.
Someone replied to my problem, i tried it and it fixed 1st time. Also seems to of worked for others
Solution:- Use a piece of thin card, a magazine cover is what i used, make sure its A4 size then try to print something, as the paper starts moving push it through! and hey presto it worked for me, everything printing fine now
SOURCE: Adding adding machine paper to the Ibico 1202
Assuming that you know where the paper gets feed in, I usually use this trick to start a new roll of paper.
First, tear off the end of the new roll so that there isn't any glue stuck on the paper.
Then, fold the tip of the paper like an arrow. > (Fold one side to the middle and the other side to the middle so both sides meet in the middle.
Then, place the paper into the slot where the paper feeds in..Look in the back of the printer for a thin slot. (Usually goes under the printer assembly) and then hit the PAPER FEED button at the same time. If the paper is in the correct slot, the paper should start feeding the paper all the way through.
Hope this helps.
Have a good day.
M =)
Please remember to leave a rating or feedback if I have helped you with your question.
SOURCE: flashing red lights and letter E on my hp printer
basically for this printer I have found that just restarting your computer will solve almost anything. make sure there is no paper left jammed in the printer and restart. sometimes you have to delete the print job in the printer que. there should be a printer icon down my your clock, right click, open active printers, and delete your file. restart your computer and try again
To fix the NON EXISTANT paper jam:
Status light is on, paper light is on - you can hear the paper feed trying to "grab" the paper, but it can't, and status light goes Red.
Take out paper tray
Reset the blue paper holders, move them tight against the paper so the paper is snug against all blue barriers. Cause: Somehow the blue paper holders got dislodged and the paper is not snug so the feeder is trying to grab paper that is slightly out of reach.
My printer has a similar problem red led flash's indicating "check paper" and also the colour flash's green.
Any advice and help will be appreciated.
