Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
What does optim ice button mean - KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
    New Friend:
OptimIce
Feature
The OptimIce feature assists with temporary periods of heavy
ice use by increasing ice production.
Press the OptimIce feature touch pad to set the freezer to
the lowest temperature setting. Press the OptimIce touch pad again to return to the normal freezer set point.
NOTE: The OptimIce feature will automatically shut off in
approximately 24 hours
Posted on Aug 28, 2017
6ya staff
SOURCE:
My PT Model IM-600 US ice maker makes cubes but continues to freeze on the ouside of the cube tray blo th cubes from falling into the bucketwhat is wrong.
cubes set too large
Adjusting the Ice Cube Size: 1. Press and hold the "Adjust" button for approximately 3 seconds until the Green Indicator starts blinking, release the button. The unit is now in Ice Adjustment mode. 2a. Press the "CLEAN" button to decrease ice cube size. The Red Indicator will flash as you lower in size and will blink when you have reached the smallest possible setting. 2b. Press the "MODE" button to increase ice cube size. The Yellow Indicator will flash as you increase the size and will blink when you reached the largest possible setting. After 10 seconds without any operation, the unit will return to the previous mode. NOTE: • During the ice adjustment mode, if the "ICE FULL", "ICE MAKING" and "ICE HARVEST" LED's all blink simultaneously, this means setting is at the regular (middle) size. • When the machine is in the cleaning stage or ice full stage, the ice size cannot be adjusted.
Dec 04, 2017 | Refrigerators
Optimal doe's the word mean
Optimal means "the best possible" or most efficient.
Feb 13, 2015 | Computers & Internet
Ice maker is slow on making ice really slow
What is the model number of the unit?
Dec 02, 2012 | Refrigerators
I get an eror message status Oxc00000e9 what does
There are 3 step to repair oxc00000e9 error
If you got oxc00000e9 error then there is a 94% chance that your computer has registry problems. To repair oxc00000e9 error you need to follow the steps below:
* Step 1 - Download a Perfect Optimizer,install this error repair tool.
* Step 2 - Click the Repair All Button.It will scan you pc for Free.
* Step 3 - Then click the Repair All Button again and your done! It is very easy to repair oxc00000e9 error.
Here are the url of Perfect Optimizer:http://www.nomoreerror.com/tidpp-oxc0000… Source(s): http://www.nomoreerror.com/tidpp-oxc0000…
Nov 24, 2009 | Acer Aspire 5050-3371 Notebook
Model #PSS26PSSA SS Freezer frequently defrosts and refreezes. When this occurs, the entire ice bin melts into the freezer compartment and refreezes in puddles. Is this a common issue with this model and...
Absolutely not ! There are two types of defrost systems - timer (which relies on compressor run time) and adaptive (newer models) which relies on sensors and an electronic control and will defrost as needed...... During a defrost cycle your comrpessor and evap fan should be off, everything off - and no, a defrost cycle will NOT thaw your food in the freezer, not even your ice should melt ! To me this sounds like a defrost control problem - First thing service should check is your defrost timer and its components (control board, limiter, defrost thermostat, etc.) something is definately wrong.
Now with the advice above I am assuming that before the defrost cycle kicks in your freezer temp was in the normal range 10F and colder (0F is optimal) and refrigerator section cooler than 40F (optimal 34F). If so, then you should not have melting ICE in your freezer.
Aug 24, 2009 | GE Refrigerators
The red light at the ice maker panel is on
The manual says to push the "keylock door" button 3 times within 10 seconds to unlock the functions of all the buttons so kids don't go round the kitchen playing with the icecubes when mommy is away. When do you do this, the red light meaning stop) goes out and the green light (meaning go) comes on. If you want to lock the functions again, press the same button 3 times within 10 seconds again.
Feb 03, 2009 | KitchenAid Refrigerators
Help for Panasonic Lumix DMC-TZ 1
For a factory reset:
Turn on the camera, push the menu button, push left, down and then right.
You are now on SETUP menu.
Scroll up to the RESET option, push right and then answer YES two times.
Nov 21, 2007 | Panasonic Lumix DMC-TZ1 Digital Camera
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
1,908 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
geob91
Dakshinamurthy...
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
