Amana AAC051FRB Air Conditioner Logo
Posted on Sep 10, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Amana ptac i have an amana heating and cooling unit in my room at school and i was messing with it to lower the temperature setting and now the LED just read 'on' in lower case letters. the ac or the heat will not turn on. is there anyway to reset it? how do i clear it so that my unit works again? thanks.
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Jan 06, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
3009
Points
First you have to hit the plus(more heat) and minus (more cool) and hit off twice then the unit should show c1 and wait till it shows L5 the hit the plus sign till you get to zero then hit off.
denver291
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 21, 2007
denver291
Contributor
Level 1:
Answers
Questions
0
Helped
409
Points
Unplug it, or turn the breaker off for 3 minutes, unit should restart.
Anonymous
Level 2:
  • Expert 80 Answers
  • Posted on Dec 01, 2007
Anonymous
Expert
Level 2:
Answers
80
Questions
0
Helped
47128
Points
139
WHAT DID YOU DO TO IT?
Amana DigiSmart PTH153B50AM 14000 BTU Heat Pump. What Amana model replaces PTH153B50AM please?
Question edited for a lot more clarity.
The new improved energy efficient versions.
The Improved Amana R-410A PTAC Unit Uses Less Energy
Amana PTAC https://www.amana-ptac.com > products > ptac
Looking to buy an energy-efficient PTAC unit for your building? Buy the new Amana R-410A PTAC unit heat pump, which reduces energy consumption by 35%.
Probably this one. Talk to your installer.
https://www.amana-ptac.com/products/ptac/hec154j
The heat pump of my Amana PTAC will not engage on heat mode. All thermistor are new, no error code flashes, but I did notice on my configuration the C5 tell the temperature but also flashes 09?
Hydronic switch open 9 E9 Hydronic switch open (if hydronic configured) - either the aquastat is defective, or the aquastat wiring is cut, or the aquastat is not present at all and the aquastat wires were not permanently connected together as per the set-up instructions.
diagnostic codes for ptac/pthp electronic control
https://www.google.com/search?q=Amana+PTAC+error+code+09
PTAC Blows Cold Air in Heating Mode when it reaches -3F less than the Set Value on the Thermostat - Model: AZ65H15DABW6
It sounds like your PTAC (packaged terminal air conditioner) unit is malfunctioning. When the thermostat is set to heating mode, the PTAC should be blowing warm air, not cold air. There are a few possible causes for this issue:
  1. The PTAC may be low on refrigerant. If the unit is low on refrigerant, it may not be able to properly heat the air.
  2. The PTAC's reversing valve may be stuck in the cooling position. The reversing valve is responsible for switching the flow of refrigerant between heating and cooling mode. If it is stuck in the cooling position, the PTAC will blow cold air even when the thermostat is set to heating mode.
  3. The PTAC's heating element may be malfunctioning. If the heating element is not functioning properly, the PTAC will not be able to heat the air.
I recommend contacting a trained HVAC technician to diagnose and fix the issue with your PTAC. They will be able to determine the cause of the problem and repair it properly.
How to bypass f1 thermostat error code on Amana ptac unit
F1 - Control Board Failure - Replace control board (ERC). F2 - Oven Temperature Too Hot - Replace oven temperature sensor. F3 / F4 - Shorted or Open OvenTemperature Sensor - Replace oven temperature sensor. F5 / F6 / F8 - Control Board Failure - Replace control board.
Amana pth153a35ac
The first 3 answers were from idiots. If a person had read her problem they would understand that it is not a oven / stove, but a PTAC unit that heats and cools a room. This type of unit is what is commonly seen in hotels and motels where the individual heating / cooling system is in each room.
Nov 29, 2013 • Ovens
Installed Amana PTAC DigiSmart unit in a patio room, a entertainment bar is located about three feet (3) in front of unit and not the room. The unit only heat and cool the area between unit and the bar...
I have seen this happen many times and if you cannot relocate the bulb of the thermostat to keep it form short cycling, I have mounted a wall thermostat and disconnected the thermostat in the PTAC and wired it in to the wall stat. You may have to install a wall stat in the center of the room away from the bar.
I have thru-wall PTAC Amana PTH093B35AM unit. I
see if you can find a new board the power failure fried it
Remington PTAC Heater/Cooler
you may have a bad heat sequencer
Will PTAC solve my problem?
Nope its a big room for 24000btu. the computation is 18sqm./ 1 ton. or 1.5 hp.
Top Amana Heating & Cooling Experts
Mike Cairns
Mike Cairns
Jay Finke
Jay Finke
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
