SOURCE: blinking lights on my hp deskjet 840c printer
There should be some error .So you know how to remove the catridges just remove it n re insert it properly.If there are any paper jams try removing it also.and by the way if you haven't installed the drivers for HP deskjet this problem may arise.So make sure you ahve don this.Also this can be happened if the printer have some hardware problems.So none of this solutions are working its better to consult it with an expert.
SOURCE: hp deskjet power lifght blinking
take it apart and see if you see anything broken if nothing take it into the store because it is more than likely a factory error
SOURCE: Printer is not printing but power light is blinking
You have a faulty ink cartridges. Try cleaning the contact points including on the carriage.
SOURCE: hp 3475 light goes on blinking, does not print
Hi
Either of the two problems make the printer blinks-.
check them out.
1. If you have given the printouts and all the pages are not printed then if there are pending printouts remaing in the printer properties the printer will blink continuosly.
2. Any of the 1 cartridge out of 2 may be faulty.
and last option if the printer cover is not closed properly it blinks.
SOURCE: my printer hp deskjet f2410
1.Check if there is low ink level in cartridge
2. Check if there is any piece of paper stuck inside
3. Unplug the power cord while its ON , Press and hold OK and CANCEL at the same time, while holding them plug in the power cable and then release the buttons.
It should fix the problem
