SOURCE: Water doesn't drain
simple one this, just clear out the waste pipe and the inside food filter and the outlet pump, also check the outlet where the pipe goes (under the sink?) its a simple blockage somewhere, if i have helped rate me, and work safe remove the plug etc
SOURCE: Kenmore elite dishwasher leaves food particles on dishes
If someone is putting dishes in the washer and obstructing the spray ams that would cause food to stay on dishes. After loading dishwasher and pushing in baskets make sure the spray arm doesnt hit any of the dishes causing them to not clean properly. If that doesnt work or is definately not your problem try removing the spray arm and seeing if it has food inside of it. Some times they get food build up in them and need to be flushed out.
SOURCE: After washing dishes it will not drain?
Check the air gap on top of the sink(silver dome next to the faucet). Clean out if plugged. I gather you did remove the plug from inside the disposal where the dishwasher drain connects.
Testimonial: "Thanks for a quick, and simple answers to my question. I was able to fix my dishwashers by removing the plug at the new disposal. Again Thanks"
