Good Afternoon bernarddunbar, thanks for your post!
From the information you have provided your Frigidaire refrigerator is displaying a "4" on the control panel. A "4" means that you could have a faulty damper. I would recommend checking the damper, which is located in the upper rear of the fresh food side, to assure that air is passing through it. If you do not feel air it could be blocked of frozen. I would then suggest checking the freezer to make sure there is no build-up of ice or food blockage. If you locate ice build-up you may need to perform a manual defrost on your refrigerator to assure proper air circulation. If food is blocking the damper you may need to rearrange food. I hope this information has been helpful. -Matt
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
