Two methods are there to use your phone as modem 1)you can use your PC suit to use your phone as modem for You need
*USB cable or Bluetooth on your mobile
*PC suit software provide by phone manufacturer(ex:Nokia,Samsung,LG,Sony Ericsson).
To use your phone as modem *install the PC suit softwareConnect your phone to PC via USB cable(I recommend you to use USB because it's faster)
*Open PC suit and select "Connect to internet"
*if its failed you can use manual setting by selecting "Connect to internet">Select access point>select the name of network operator from the access point list(if you did't get your network operators name in the list you need to contact your network operators customer care they provide the access point name you need enter this access point in the manual updation list now it works.
2)You can use Bluetooth technology to connect to internet (2 methods are there)For this you need
*Bluetooth on your PC and phone To connect(in windows OS)
*Click on Bluetooth symbol on task bar
*Select add device select from device which can be connected to your PC list(set your Bluetooth device to visible all mode)
*Add your device to your PC Add completion of the above...
*Again click on Bluetooth symbol on task bar
*Select "show all devices"
*now select your device(one click) at this time 4 options appears on top your devices list
*select connect using>access point
and 2nd method is *Again click on bluetooth symbol on task bar
*Select "show all devices" *double click on your device
*select connect to internet from the dialog box which appears after selecting the your device Above options are with respect to Window 7 and Windows related operating system. Thank you...:) ANY SUGGESTIONS?
if you are using a ppoe connection then save your isp account user name/password in the modem weather it be a cable modem or a dsl modem and then setup and configure your access point device and SAVE your settings in the device. if you using a dhcp connection from isp modems then just connect your access point device and setup amd configure your settings and SAVE them as well. the only thing that i can think of is that you are not saving your settings and configurations. then when you you loose power the device reverts back to the default settings. also note that if there is some kind of "auto-configuartion" in the access point you may want to change that to manual configuration and create a new user name/password for your access point as well. please you MUST be hardwired connection when setting up the access point for the first time. please refer to the user guide for your access point for more detailed help on settings and configurations and how to save them in your device.
You need PC suit software provide by SAMSUNG
*install the pc suit software
*Open PC suit and select "Connect too internet"
*if its failed you can use manual setting by selecting "Connect to internet">Select access point>select the name of network operator from the access point list(if you did't get your network operators name in the list you need to contact your network operators customer care they provide the access point name you need enter this access point in the manual updation list and try to connect now.....
2)you can use Bluetooth technology to connect to internet
For this you need
*Select add device select from device which can be connected to your pc list(set your bluetooth device to visible mode)
*Add your device to your pc
your device
Thank you
Yes...there are lots of things you need to tweak. Contact Motorola Support (they bought Symbol) at 1-800-653-5350. You may need to create a script to run with the CISCO AP's...Symbol defaults to their own Access Point settings. Good Luck. If you need further help, our company, qdata, can help (for a fee)
You can connect a console cable to the console port and login using a freeware terminal emulation app such as Tera Term Pro. The default password is: Symbol
PDF manual: http://www.guardit.cn/UploadFiles/symbol_ap4131_engmanual.pdf
Use chapter 5 for instructions on creating a new authentication key that will match your computer setting.
on the info i could find it only supports WEP.
but if your issue is to be more secure look up if it supports a sort of mac filter.
this will only keep everybody out of your router but your signal will only be WEP encrypted.
