You don't need any special software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa ( http://picasa.google.com ).
Software is not compatible with win7... need xp for it to work
SOURCE: Olympus Camedia 4.0/ C-4000 Zoom and Windows Vista Operating System
Doubt the software will work on Vista. If you do have the disk, before you click on the install program, right click it and use the "XP compatability" mode. I would dual boot to an XP partition to take care of all your XP needs. Its a bummer but that is what Im doing...
SOURCE: Need software
To learn about the new and free version of Olympus Master 2 software go to: http://www.olympusamerica.com/cpg_section/oima_softwareMaster.asp Click on 'Free Download' to register your email address to receive an email containing a link to download either the Windows or Mac version. This software replaces all previous versions of Camedia Master 4.x and Olympus Master 1.x and is XP and Vista compatible.
SOURCE: New computer with Windows 7. Olympus Master will
Hello
Thank you for using FixYa for your problem
From what I can see at Olympus there is no driver updates for the Master series to work on Windows 7
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
SOURCE: Zoom Error on Olympus SP-500UZ
I have this exact same camera and I had the exact same error. Since it was no longer under warranty, I decided to see what I could do myself. The zoom tube has a ring surrounding it and on the bottom of the ring there is a tiny Phillips head screw. I removed the screw and loosened and jiggled the ring a little bit. I then turned on the camera and it worked. I replaced the screw and it still worked. I don't know if I was just lucky or what. I would not recommend trying this if the camera is still under warranty. I figured I had nothing to loose.
SOURCE: Can't connect to my laptop using Windows 7, any
Who can help me pls, video for my cam samsung sc mx20 cant ue in movie marker, and if i convert this movie only problem. ths!
