My Bush HD-220RWNB stop every 24 hrs & I had 2 turn the defrost timer on manually to get it starting again, I installed a new defrost timer but it still stops, also I have to defrost it every 2 weeks because keep building ices & stop cooling. What is wrong with it? Many thanks
Most of these freezers have an automatic defrost cycle.
after so many hours of chilling it will stop and run a de-icing cycle.
this is accomplished by one or two heating elements.
if one of the elements is burned out it will not run the defrost cycle.
and will ice up quickly.
depending on the model the heaters will usually cost about 15 to 20 dollars and they are easy to replace.
look up the model of your freezer and download the pdf files they will usually have a pictorial diagram showing the location
a defrost timer usually does nt fail on them unless it is physically damaged.
Testimonial: "Hi, that explain why ice up every two weeks but why doesn't switch back on to the cooling cycle, it just stop in the de-icing cycle or I've got two issues here? Many thanks"
SOURCE: Please help!!!
If not defrost, could be timer, or heater is not working for some reason. Bad time can cause lots. Compressor could run during defrost, heaters not working, and such. Doubt that the t'stat would be the fix. Could be having a defrost cycle that is too short. Repairing all 3 plus the cost of a tech could get very pricey.
SOURCE: freezer won't start after defrost cycle
It might be the timer motor, if it doesn't run. neither does the timer. Easily replaceable and cheap. good luck. John
SOURCE: auto defrost is not working on my zanussi ice free fridge /freezer
You have a defrost problem. It means you have 3 parts that can be involve ( timer, defrost thermostat, element) most of the time it's the timer. Hope it was helpful. :)
Francois
