You have not said how you are viewing the pictures is in iphoto or picasa or something else. Or are you viewing them directly from the SD card?
What I think is happening is that when you are viewing them in image capture you are viewing them directly on the SD card therefore it will not allow you to save them to the card. You need to import them onto your imac through the import all button to your pictures folder. Then you could you use preview to view them or better still you could use (if you have an intel imac) picasa which is free to download off the web. This is what I use, it allows you to import them from your camera, edit and do other stuff with your pictures. Hope this helps.
I connect the camera to the IMAC using the cable - then view the pictures using "Image Capture"....
