Question about HP Deskjet F2480 USB 2.0 All-in-One Color Inkjet Scanner Copier Photo Printer Black
Cannot make the printer work after I changed the ink cartridges?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • HP Expert
  • 307 Answers
You can validate the HP60 ink cartridge's electrical health by running the 'Tap 41' diagnostics test (this procedure is specific to the F2480 model). Refer to DIAGNOSTIC TAP 41 video procedure at the following link on how to activate and read the service test: http://inkjet411.com/?page_id=440
1. While holding the Power button, press Cancel (X) button 4 times, then press the Color Copy button once.
2. Release the Power button.
3. The 'Tap 41' diagnostic test print should print.
--- Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health). A good HP 60/60XL color cartridge should display 1248 good nozzles, while a good HP 60/60XL black ink cartridge should show 336 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to video on how to read the printout. http://inkjet411.com/?page_id=434
---- If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
For information on North American ink refill services at a major retailer near you (should you wish to save ~50% on ink costs), general printing problem resolutions or advanced HP printer diagnosis procedures (advanced cartridge diagnostic tests/cartridge error bypass & printer reset methods, etc.), please visit Inkjet411: http://www.inkjet411.com
Posted on Sep 04, 2013
6ya staff
SOURCE:
Epson Stylus NX415 does not recognize ink cartridges. Cartridges are Epson 88's. Worked for awhile, and then stopped recognizing them. Tried powering down the printer, cleaning the cartridges, turning...
Epson Printers are sensitive in terms of Ink Cartridges.. The latest Epson Printers does not have ink reseter.. Ink reseter are already built-in on the ink cartridges.. The problem on this printer is when you have a cartridge on your printer, let say, 30% of the ink level, even though your ink is new, and you change it without using the right ink replacement method, it will recognize your ink as a 30% ink level. When your ink level drops to 0%, but you have remaining 70% of the ink, it does not recognize it anymore. The chip on the ink cartridge is already registered as an empty cartridge.
May 28, 2011 | Epson Stylus NX400 InkJet Printer
How to chang ink
When it is time to replace an ink cartridge in your HP inkjet printer, you will receive a pop up message on your computer screen. Replacing an ink cartridge is just part of owning an inkjet printer, and a tradeoff with the high quality imaging you are able to achieve on an HP inkjet. It is not something a professional needs to do; just follow these simple instructions to complete the change and get right back to printing.
  1. Allow your inkjet printer to run entirely out of ink. Unless the quality of your images is suffering, there is no problem with letting your ink run low.
  2. Open the printer door. It should fold from the top down toward the tray. When it is open, it should expose the inner workings of the printer.
  3. Press the change cartridge button. It is at the top of the printer next to the power button.
  4. Pull on the green top of the inkjet ink cartridge and remove it up and out of its holder. Do this gently so the printer is not damaged in the process.
  5. Recycle the empty inkjet cartridge or have it refilled at an ink refilling center.
  6. Carefully remove the tape from the refilled or new inkjet ink cartridge and insert the cartridge in the same orientation as the one you removed.
  7. Push on the green top until the cartridge snaps into place, press the cartridge change button and close the printer door.
Good luck.
Apr 26, 2010 | HP PSC 1315 All-In-One InkJet Printer
It tells me the cartridges are empty, then when i open the lid it says no cartridge! its not been used for a few months, and i refill them with generic refills...any thoughts? tried the switch off and on -...
Hello ,
Start by opening your ink cover and read the LCD screen; this will alert you as to which ink cartridge is not being recognized; make sure the cartridge that it is telling you is empty has been changed.
If the unit is still not recognizing the cartridge you have changed, follow the steps below.
  1. Unplug the power cord for the printer unit.
  2. Open the ink cartridge cover and remove all ink cartridges.
  3. Close the ink cartridge cover.
  4. Plug the power cord back in.
  5. Reinstall the ink cartridges.
Make sure that your ink cartridges are full and that they are genuine brother inks; refills or generic ink cartridges are not guaranteed to work properly.
Thanks,
Pat
Mar 29, 2010 | Brother MFC-620CN All-In-One InkJet...
Changing the black cartridge also require change of color
The printer is very good.I ve been using it for approx 1 year now.The printer works on a combination of both black as well as colour ink cartridges.If any of the cartridge is empty,printer will not print.Kindly call Kodak with your problems at 1800 421 6699 and they will take care of the issue for you.
Oct 04, 2009 | Kodak ESP 5 Printer
I changed the black ink cartridge and the printer
Calibrate your new blank ink cartridge, have some nozzle check, cleaning check, and printer alignment. This are procedure that new ink cartridge will have to calibrate before you use. Epson printer are very sensitive when capable of changing ink cartridge. Unlink HP directly work without any print test because the cartridge head and ink join together, Epson with ink cartridge and the head separate.
Have some test on it at Printer Maintenance.
I'm sure 100% works on it.
Sep 23, 2009 | Office Equipment & Supplies
I changed the black ink cartridge and now not working
Did you remove the plastic sticker over the print head of the cartridge?
Are you using a refilled cartridge? Most cartridges have a sensor that tells the printer how much ink is left. When companies refill them they do not replace the sensor, so a completely full cartridge will still tell the printer that it is empty.
Jul 01, 2009 | Epson Stylus C48 InkJet Printer
Brother's printer has ink cartridge problems.
no red marks when I check the print quality but cattridge new
Mar 13, 2009 | Brother MFC 240C All-In-One InkJet Printer
Why won't my CX9400F recognize Epson ink cartridges
The Epson CX9400F printer seems to require replacement of all the color ink cartridges, even if only the Black is empty.
I print almost exclusively in Black, but with my first change of Black, I was forced to change all the color. At the time I thought Epson did not provide completely filled color ink cartridges.
Just yesterday, I replaced Black and the printer complained it did not recognize the rest of color cartridges. So I replaced all the other color ink cartridges and now it works fine.
You might want to check out www.clickinks.com for cheaper, mail order alternatives which are Epson ink compatible, if you are not in a hurry.
ew
Feb 23, 2009 | Epson Stylus CX9400 Photo Printer
Printer won't recognize ink cartridge change
changed black K cartridge with new one but still shows black toner empty! Could toner cartridge be faulty?
Dec 05, 2008 | Konica Minolta magicolor 5430 DL Laser...
Dell 725 printer no manual need to change ink cartridge
Here is the manual
http://support.dell.com/support/edocs/systems/725/en/index.htm
Replacing an Ink Cartridge
  1. Turn on your printer.
  2. Lift the front cover.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  1. Press down on the ink cartridge lever to raise the ink cartridge lid.
  1. Remove the old ink cartridge.
  1. Dispose of the old cartridge properly.
  2. If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
  1. Insert the new ink cartridge.
  1. Snap the lid closed.
  1. Close the front cover.
Feb 09, 2008 | Dell 725 InkJet Printer
HP Deskjet F2480 USB 2.0 All-in-One Color Inkjet Scanner Copier Photo Printer Black Logo
310 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
