SOURCE: digital power saving mode
Are you sure someone hasn't changed the power setting in windows. I've seen similar tricks pulled by so called mates. :-) If windows is OK then check the manual for the monitor and if you still can't crack it take it for a ride to the repair shop. It is under warranty after all. BMW
SOURCE: Ao ligar o Computador e o Monitor, ele arranca mas
http://daf575.wordpress.com/2010/03/20/issue-with-my-hp-l1955-lcd-flat-panel-monitor/
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
SOURCE: My LG Flatron L1520B monitor "Locked/Unlocked"
press the power button for 1 mn and release it if still the same problem change your inverter board.
SOURCE: Flatron W1942TQ monitor has "OSD Locked" message
Press and hold menu button for a few seconds, pressing and holding, acts as a toggle. So if OSD LOCKED still appears, pressing again UNLOCKS.
