Frigidaire FRT15B3A Top Freezer Refrigerator Logo
A
Anonymous Posted on Sep 01, 2013
Frt21lrgw2 What is the cu in. of this refrigerator?
How many cubic feet is my Kenmore model 253.54362409 refrigerator please?
Total Refrigerator Capacity 26.70 cu ft Measure Freezer Fresh Food Total Capacity Cubic Feet 7.66 cu ft 19.02 cu ft 26.70 cu ft Liters
Cubic feet of Maytag mf 12665xem8
Apparently it is an MF i and not an MF 1 (one).
Maytag MFI2265XEM Refrigerator
25.5 cu. ft. total.
Freezer 6.6
Fridge 13.6
Even though their maths is a bit funky!
http://fridgedimensions.com/refrigerators/mfi2265xem/
Measure Freezer Fresh Food Total Capacity Cubic Feet 6.60 cu ft 13.60 cu ft 25.50 cu ft Liters
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Manual available?
SAMSUNG RS261MDRS/XAA USER MANUAL Pdf Download.
www.manualslib.com > ... > Refrigerator > RS261MDRS/XAA
Samsung side-by-side refrigerator service manual (33 pages). Refrigerator ... 26 cu.ft. french door refrigerator rf267aebp user manual (ver.0.4) (44 pages).
Samsung - RS261MDRS - 26.0 cu. ft. Side-by-Side ...
www.searsoutlet.com > Refrigerators & Freezers
Rating: 4 - ‎228 reviews
Side-by-Side Refrigerator - Stainless Steel (RS261MDRS) at Sears Outlet today! ...Overview; Specifications; Manual & Warranty; Reviews ... 26 cu. ft. for greater space, convenience and access - Spacious enough to fit about 19 bags of ...
2helpful
Need to know how many cubic feet my frig is so I can compare when shopping for another.
This is the information I could find.
Refrigerator Type Side-by-Side Total Capacity Cu. Ft. 21.7 Cu. Ft. Refrigerator Capacity Cu. Ft. 14.40 Cu. Ft. Freezer Capacity Cu. Ft. 7.30 Cu. Ft. Energy Star® Qualified Yes
for more information try this link.
Whirlpool Appliances for the Home Kitchen and Laundry Room
Bob
What is the cubic feet of the Kenmore refrigerator Coldspot 106.5706602
According to your model number, this refrigerator has a total capacity of 25.2 cu. ft. It has 15.4 cu. ft. in the refrigerator section and 9.8 cu. ft. in the freezer.
1helpful
Water is leaking from freezer door. may have put holes in something, putting locks on door. locks are on left side of unit(facing unit).4 holes in door,about half way up door. four more across from them......
good evening sir.
well about ur problem, plz check it out in a near service center, as ur freezer is fragile part, connecting directly with compressor, any slight damage r rough handling may result in leakage of Coolent !! which is sometimes quite toxic.
or else, if u can manage then try fixing it a rubber washer of reqired size. this will definetly stop the leaking of water..
thank u
1helpful
How do I get the red&white wires out of a Starter/overload assbly
it's very easy but alittle tricky. use something thin and hard. there's a small tab on those connecting clips that you must press down while pulling the wire out of the relay.if you have a replacement relay on hand, then go head and carefully crack open the relay in order to remove the wires.
MAKE SURE YOU UNPLUG UNIT B4 DOING THIS.
Jul 16, 2009 • Freezers
Warm refrigerator compartment
We had similar problem. Found the interior lights of refrig. were not turning off. Found out this was a recall problem and was fixed by sears for free.
Top Frigidaire Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
john h
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
