SOURCE: Peavey PR15-D Powered speakers, Power on but no sound.
Check for impedance ( resistance) in ohms on the speakers disconnected from the circuit using a volt/ohm meter. I think the woofers are 8 ohms and the tweeters are 8 ohms. Also check for bad solder joints where the jacks are soldered to the circuit boards.
SOURCE: No sound coming out of speakers when turned on
If you get absolutely no sound, not even a pop when changing the standby switch, this probably means the rectifier OR the switch has failed. The red light just means power is getting to the power transformer... probably fuse is OK.
SOURCE: I have 2 Peavey Impact 1015s and 2 PV 118 Subs. I
Just a note regarding connecting: USE BALANCED lines everywhere you can. Use either XLR if available or TRS type cables. This will reduce noise pickup.
Another hint: For SAFETY of your equipment run ANY interconnected devices from the SAME power source. DO NOT say power the amps from one place and your other equipment from a different outlet. Afford a power distribution system that feeds from a single receptacle or nearby receptacles near a common electrical panel. This will ALSO help avoid noise as well as the hazards to your equipment from ground loops.
SOURCE: I don't get any sound from my peavey viper 120
Suspect switch contacts that are a part of the headphone jack.
SOURCE: Peavey SP3 (older model) Can not get any sound
They have a "soundgard" protection network that uses a polyfuse and an automotive lamp. Open the unit and check the circuitry. Both the polyfuse and he lamp may be blown. Do ohmmeter check of these, otherwise the horn is blown.
