If you're using a pedal. the cat 6 wire that connects the pedal to the amp. can be coming out of the "phone jacks" that line 6 uses, all it takes is for that wire to stretch and if one line breaks . it changes the protocol. sounds like yours is intermittent. put new connectors on each end (after checking continuity),
No sound
• Are the other devices or headphones connected
correctly?
Check the connections. ........................................ (see p.6)
• Is the power of your amp or mixer turned on?
• Is the [MASTER LEVEL] knob raised?
• Is the Global mode Group 4 "MIDI Local" parameter
turned On?
Check the setting of this parameter.
• Are the bars of Drawbar 1 or 2 pulled out?
Pull out some of the bars.
Also check out this site and scroll down and do the "Factory reset" by holding down the buttons they say... AND please note that you have to hold them for a while during this.
