Had to have bad wireless modem changed. Network printer no longer working. Found red light on ESI 2833. Reset pocket pro that resulted in green light on pocket pro. Network printer is still not recognized on network. What should I do next?
SOURCE: How to reset Pocket Print server Extended Sys ESI 2833?
Disconnect the power. Press the small test button and keep it pressed, while you reconnect the power AND wait until the green LED is on again.
SOURCE: My network HP laserjet 4Vprinter
try Disconnecting and reconnecting cables. Changing cables and pocket print server.
if that does not helps your system needs reconfiguration
just click this link directly
http://docs.sun.com/app/docs/doc/806-3323/6jcfsj369?a=view
This will help. Thanks please keep updated. please dorate the solution positively .thank you for using fixya.
Print the network
settings page to identify if your printer is connected to your wireless
network:
1. Press Setup on
the printer operator panel.
2. Press the right or left arrow button until Network
Setup is displayed, press OK.
3. Press OK at Print Setup Page.
4. Press OK when prompted to Load Paper.
5. Press OK. The network settings page will now
print.
Check the Network Card Status, SSID, Trouble Code, TCP/IP Address.
SSID should be the name of your wireless network. Otherwise, you may need to
reset the printer's wireless network settings.
How to
reset network settings:
1. Press Setup.
3. Press the right or left
arrow button until Reset Network Adapter Defaults is
4. Press the right or left arrow button to display Yes,
pressOK.
Once the Wi-Fi light turns on to solid orange, run the Lexmark
Wireless Setup Assistant on your Mac.
