Samsung 7.3 Cu. Ft. Electric Dryer Logo
John Silcox Posted on Sep 03, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dv210aew/xaa Dryer has no air blowing in from the rear of the drum in any setting. I thought it was a heater issue but upon checking (and making sure I wasn't in Air Fluff mode) I determined that no matter the cycle, there's no air being blown into the drum.
Paul
Level 2:
Sergeant:
  • Expert 381 Answers
  • Posted on Oct 31, 2013
Paul
Expert
Level 2:
Sergeant:
Answers
381
Questions
0
Helped
146110
Points
960
Odds are the heating element opened or the hi limit or the safty thermostat
  • John Silcox
    John Silcox Oct 31, 2013
    It was the high limit that had failed. Replaced it and dryer works like a charm.
5 Related Answers
Anonymous
  • 43501 Answers
  • Posted on Jun 18, 2010
SOURCE: the dryer is just over a year old and runs normal
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Anonymous
  • Posted on Jan 01, 2011
SOURCE: I have a DV306LEW/XAA dryer that is about 4 years
There is a thermal shutoff on the heating assemly that will turn off the dryer heat. Also, we just experienced a fire in ours due to lint build up in the body of the dryer even though we vacuumed out the lint trap on a regular basis. To look in this area, you have to take the top off the dryer and then the front. You can look by pulling out the dryer outlet connection and a flashlight. Make sure to put it back in correctly though to avoid a fire.
Anonymous
  • 146 Answers
  • Posted on Jan 28, 2011
SOURCE: i have Samsung-7.3 Cu. Ft. 7-Cycle Electric
i would take the plug panel off the back and make sure you are getting the full 220 volts on the terminal,, (it could be in the cord itsself), if that is not your issue, it might be your main board, since it is new i wouldn't tear into it because it will void the warranty
Anonymous
  • 1531 Answers
  • Posted on Feb 02, 2011
SOURCE: I have a front load
You will need to check the thermal fuses they are located inside the cabinet.you will have to remove the lid ny taking the screws out of the back then remove the four screws that hold the contol panel in place.
Then take out the screws that hold the front panel inplace,open the door and remove the two screws in the front and the panel will come off.
If you have a multi meter you will need to check the continuity on all the thermal fuses there is one on the blower housing it is black in color and two on the heating element can.Be sure to unplug the unit prior to checking the fuses.
RyanFanMan
Ryan Nguyen
  • 342 Answers
  • Posted on Mar 04, 2011
SOURCE: Samsung Model DV220AEW/XAA 7.3 CU
sounds like the heating element has gone or the themal component has died. you can test it with a multimeter by setting it to ohms and putting it across the terminals of the heater and if you get a reading then it is not an open circuit after that test the thermal cutoff the same way if it has a reading then it is good but if it stays at 0 then it is no good
Dv210aew/xaa THERMAL FUSE keeps blowing after replaced 3 times. Cleaned out exhaust and replace heater element and thermostat switch, what else can it be the problem?
on the blower housing there's a thermistor that takes the place of the cycling t-stat,if that's not working correctly the dryer will run to hot or not hot enough,also check the duct that the lint filter slides down into,make sure that isn't clogged with lint,then run the dryer with the vent line disconnected to make sure there isn't anything blocking it,how long is the vent line?if it's a long run i stick a leaf blower into it and blow the stuff to the outside,you should take the dryer apart and clean it at least once a year and blow out the vent line so things like this don't happen,part number for thermistor is DC32-00007A.what thermal fuse are you changing there's one on the heater box and one on the blower wheel housing if it's the one on the blower wheel housing you could still have a block in the vent line or a thermistor problem,if it's the one on the heater box you could have a bad high limit that's the t-stat next to the thermal cutoff on the box,one more thing when you changed the element did you buy the whole part with the t-stats,if not if you ever have a problem with the element buy the whole thing you get the element and t-stats together and you just pull the wires off and change the whole heater.if the vent isn't clogged and you changed all the t-stats and it still pops you could have a bad computer board,do this,when you change the thermal fuse,start it with the vent line disconnected,put it on air fluff and start it,if the heater comes on the element is shorted one of the coils are touching metal,if the heater doesn't come on run it with the vent line still disconnected and see what happens,those t-stats are pretty reliable but one could be bad but the board could be the problem but the dryer is running to hot and popping the thermal fuse,use a watch to time it,when it starts with no clothes the heater should stay on for no more than 3 to 4 minutes,then it should shut down,for a minute to a minute and a half and come on again but now it should only stay on for like 50 to 60 seconds and shut down.sorry to make this answer so long but without being there i'm just trying to tell you what i would check.let me know what you find,keep an eye on how long the heater is staying on if you think it's on for to long while you're checking it stop it and put it on air fluff to cool it down so you don't cook the thermal fuse again
Oct 07, 2017 • Dryers
Samsung dryer model DV210AEW/XAA it isn't too now we're restart button is
here is the manual for your model. good luck
http://www.samsung.com/us/support/owners/product/DV210AEW/XAA
I own a Samsung dryer model DV218AEB/XAA. In both the sensor and timed cycles it shuts off early and goes dead for about 30 minutes before it comes back to life and the load can be restarted, only to
I have a good idea that it may be the following;
Drum Roller Axle
This dryer has drum support rollers. There will always be two supporting the rear of the drum, and on some models there may be two supporting the front of the drum. The rollers must spin freely to work properly. If the roller axles are worn out the rollers may not spin freely which can overload the motor and the dryer stops. If the dryer stops mid-cycle, remove the belt and spin the drum, it should spin freely. If not, check the rollers and roller shafts.
You can check out other possibilities and order parts here using the following link;
http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/2---/Dryer-stops-turning-during-cycle
Good Luck!
Rich Lilja
1helpful
DV210AEW/XAA won't heat
More than likely the element is shorted or the thermal cutout on the element assm has failed you can test them for continuity if they don;t have continuity they are bad. 1st reset your house breaker, the dryer needs a full 220volts to turn the heater on, if that is good check the cord and make sure you haven't lost 220 there, then check the element and cutout.
I have Samsung-7.3 Cu. Ft. 7-Cycle Electric Dryer-White-DV210AEW/XAA SKU: 9739916 this is my first time using this dryer just got it opened the door to check the dryer and closed the door pushed the power...
2helpful
Drum rotates. No Heat. Kenmore Electric Dryer
check the thermal fuse on the top of blower wheel housing,also while your there take off the cover of the housing and clean all the lint out,if your fuse was popped the lint buildup did it,check outside and make sure the air from dryer is blowing out and is not blocked,if it is blow out vent line if it's a long run with a leaf blower,if the thermal fuse is good read out the heater with a meter and if that's good read out the t-stats
2answers
My Maytag Performa dryer is blowing out cold air. How can I fix it myself?
remove frt cvr,then top then remove drum belt and drum, check for open heater element, defective thermal fuse,hi-limit switch, open neutral to element if it uses the neutral connection
Dryer not heating properly..taking longer to dry clothes
If there's heat inside the drum the heater coils should be ok, however your model has 2. With the door open and the machine running, look inside at the back of the drum and look for 2 glowing element coils. If one is not working you will not have enough heat.
Check the exhaust vent, make sure it's not kinked or squished behind the machine and that the outside vent is not clogged with lint. You should feel air blowing freely to the outside.
If there is no heat, first check for 240V at the outlet. If you have 240V, it could be the element, the hi-limit thermostat, the thermal cut-off, the timer, the motor or a wiring issue (loose or shorted).
Good luck!.
Mar 06, 2009 • GE Dryers
Top Samsung Dryers Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
