Users of brother printer need to know details that how to fix Brother printer toner error so just make a call on Brother Printer customer service 1-802-618-6092 anytime 24*7 and experts are there to help you 24*7. Call on Brother printer Support 1-802-618-6092anytime and sort all issues of Brother printer with the help of technicians.
The hard drives are in a USB externa enclosure, set up as RAID 1 and are formatted as Mac OS Extended (Journaled). I do not save any TM back ups to them and they work after a restart and then sometime later start to provide the error message anytime I try to save to them. A restart usually fixes the issue for a finite period of time. Disk Utility runs and tells me the disks are fine. I never have trouble accessing data from them.
For more help visit cbrtechsolutions
SOURCE: my printer brother DCP115C ''UNABLE TO CLEAN error code 50''
Machine error 50 is a error in Purge unit.You can't fix it by yourself and your printer need service.In most case the cost of repair is more than cost of new printer.
SOURCE: error 50 brother dcp 130 d
on my DCP 130C display appear an errore message "imp. stamp 50". This is an error message in italian language that indicate impossible to print, error 50.
Please, have you some suggestion to resolve this problem?
Thansk in advance
SOURCE: clean unable 46 error on dcp 135c brother printer
the proper reset code sequence to reset DCP printers without numeric keypad should be as follows:
1. press buttons OK, Menu, Mono Start one by one, followed by up arrow key four times. this should all be done as short a time as possible, around 3 seconds.
2. enter maintenance mode 80 by pressing the up/down arrow key and set key to select numbers 8 and 0
3. press blue MONO start button to select PURGE which requires it to be pressed a number of times before PURGE appears on the LCD screen of the printer
4. then use the up'down key and OK button to enter the reset code 2, 7, 8 and 3 keys to reset the counter : Note this does not overwrite the number next to PURGE on the LCD screen but once the last number is added it gets reset to 0000
5. press Stop/Exit key to go to root of maintenance mode
6. enter 9,9 to exit maintenance mode
