I believe I overloaded the dryer as I heard some squeaking noises when I turned the dryer on. I immediately turned it off and took some clothes out and proceeded. An hour later I went to retrieve my clothe and they were still wet. I ran another cycle and about an hour later they were still wet. At that point I noticed how quiet the dryer was and I believe its not ''tumbling'' the way it should. Is this a belt issue? If so how difficult is it to change?
Probably is a belt issue. It'll take two people to change. You'll have to take the front off to access the drum and be mindful of the belt route. Good luck.
It could be the rear bearing or if not it have your honey take it apart again and inspect the rear rollers, if they turn freely then inspect the front bearing assy it is on the the door and if it looks worn down then it is allowing excessive pressure on the rest of the unit .
The sqeak is from one of two items surrounding the drum. It can be the belt with a bad roller on the belt tensioner or the liner surrounding the round lip of the front part of the drum to the dryers front panel.
If the squeak can be heard dy the dryers door it will be the felt liner. If deeper inside it will bet the belt
Sears has replacement parts online and at all repair centers for sale
there are two possibilities for this question. 1) there is an idler roller that give the belt the correct tension . unplug dryer and remove idler roller see if it spins freely if not replace it @0 there are two drum rollers in back of machine thatdrum rides on remove drum it's self explanitory how to remove drum and very easy also. you can roll these wheels and check for free movement visually check them ,one or both should be worn out or the bearing in the wheel has failed before putting old or new wheels back sand the wheel shafts to get any gunk off them and that's about the only thing that can make a dryer squeek
Squeaking noises are hard to find unless u open it and pin point where its coming from.. you can open the back cover if you are comfortable doing so.. let it run to see if you can heard... sometimes the bolt holding the pulley to the drum is loose and need to be tighten. Other possible is the shocks came loose or when install new.. the shipping materials were not remove..
there are 2 drum rollers at the back of the dryer. shut off power, pull drum and you will see 2 rubber wheels. there is a little plastis triangle that keeps the roller in place. try spinning the rollers . they probably will not spin too freely. remove triangles ,inspect inside of roller the stainless steel bearing may have gunk on it try to clean off . also check shaft roller rides likewise remove any debri use a little rubbing alcohol to remove gunk. also check the idler roller that routes the belt for the same things. good luck
