may be battry is outdated or extra fully charged thats why sometimes it react like this or the size also bigger than normal battry so try new battry or check the PIN which is connected to battry when u put battry in mobile...thank you
Could be - I would take the scooter or battery to a car store and they will load check the battery - That is, they will cause the battery to do work, and measure the voltage. Measuring volts while the battery is at rest will indicate full voltage. That would be a flawed test.
check to see if the battrie is full charge most likely the battrie is dead charge it for two or three hours if it dosent start the battrie is probley bad , clean the battrie termnails or if you have jumper cables jump it if it starts let it run for 20 minutes shut it off and try to start it if it dont start most likely the battery is bad
Hello my name is Ibrahim Makki and might help you maybe your battary date has expired or you had put the battarey on charge for long time so it blow or leave it for long time , try to buy a new one
