My e 63 isnt supporting themes which are being downloaded from the following web sites example zedge and symbian web site
Don't worry this is simple settings issue.
Note:Please download only E63 series Themes only.......not other phone themes...
To solve this problem follow the steps:
1)Go to Menu-> Tools-> Application Manager
2) Then press (options) button, select (settings)
3) Make sure <Software installation > is set to "All" and < Online certif.check > is set to "Off"
Some time you get certificate expire to solve this you have to change the date.This is to prevent the users from using expired application:
If you encounter Expired Certificate error during installation, please set your phone date to 03/03/2007 before installion of the theme .You can reset your phone date back after installation.
If still the problem persist Change the PC date also because it will get synchronized with your mobile and try different dates so that it will match the application date.(Reason is every application is valid for a period of time
example.from 03/03/2007 to 03/09/2007 so you have to give date between this.So try old dates usually some years back...
Please do rate the solution if the issue is resolved or post a comment for further assistance.
thank you for using fixya have a nice day:-)
certificate expire
