A
Anonymous Posted on Sep 04, 2013
Riset ricoh aficio 1224c code sc570 - Gestetner DSc224 Copier
1helpful
1helpful
Imprimente ricoh afico 1224c sc670
SC 670 - Engine response error.
After powerig on the copier machine,a respons is not received from the engine .possible defect controller board or SBCU installed incorrectly.Try reset the code to turn ON/OFF the main power switch.
How do I scan a document from my Ricoh 1224c copier to my computer?
have you installed the driver for its scanner? here's the link http://www.ricoh-ap.com/downloads/GetDriver.aspx?CID=1&pn=Aficio%u2122%201224C&path=http://support.ricoh.com/bb/html/dr_ut_e/ra/model/c24_32/c24_32en.htm
1helpful
Hello i have ricoh aficio 1224c color . but the is have problem error sc792 . please help me best regards Salar
SC 792 :Finisher error .
The machine does not recognize the finisher , but recognizes the relay unit .
Possible causes :Defective connector
defective cable
incorrect installation
Ricoh (Aficio) 1224c. code sc670 we want to decode this codesc670
Hi, it looks like a bad controller board. Try resetting it from in service mode with 7807. Also if you can view or printout the error history with 5990-004 for further trouble shooting. Hope this helps
1helpful
2answers
Error Code SC570 for copier Aficio 1224C
It could be covering the sensor. Clean the fuser oil sensor off and see if it goes away.
3helpful
Error code SC305 for Photocopier Ricoh Aficio 1224c
Its a charge corona cleaning error. Try turning the power off, wait 10 seconds and turn it back on.
If that doesn't reset it, it could be the pcu, toner collected on the mechanism.
If turning it off and back on isn't fixing it, you should get a technician to look at it to see what the trouble is.
10helpful
2answers
Error code SC305 for copier ricoh aficio 1224c
This SC code relates to the charge corona cleaner not working or not working properly. the charge corona is located towards the bottom left of the machine after opening the front cover. It will have a screw you can undo by hand and a cable with an end like a telephone cable plug. toner may have fallen in to the unit or the motor that drives the cleaner along the wires has decided to jam up. remove the charge corona and blow it out with compressed air. You can also remove the end of the unit and check that the motor is not gummed up. Be very careful you do not break the hair thin corona wires! Hope this helps.
Dave T
Top Gestetner Office Equipment & Supplies Experts
Daniel Blask
Daniel Blask
ZJ Limited
ZJ Limited
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
