GE WBSR3140DW Top Load Washer Logo
A
Anonymous Posted on Sep 04, 2013
Ge wsm2420tcaww remove front panel" - GE WBSR3140DW Top Load Washer
Onno
Level 1:
  • Contributor 1 Answer
  • Posted on Feb 05, 2023
Onno
Contributor
Level 1:
Answers
Questions
0
Helped
296
Points
It took us a while to figure it out, but it's possible if you have an old model stylemaster WSM2420TCAWW, this is how you get to remove the front panel.
1) unscrew the cover between the dryer and the washer
2) there are small bolt-like screws behind the washer lid, use a wrench to unscrew them
3) now you can just slide the washer lid towards you, and it will come off
Hope this save someone some headaches!
3 Related Answers
Anonymous
  • 1073 Answers
  • Posted on Apr 12, 2008
SOURCE: front panel removal
use a small putty knife move in 4-5inches from each edge of the frount push in the putty knife to the top release clip . it will feel springy when you have found the clip. push in the putty knife and pull out on the side of the panel, do the same process on the other side and it is loose
Anonymous
  • 576 Answers
  • Posted on Mar 07, 2010
SOURCE: How do you remove front panel to locate leak?GE Profile WPRE6100G
I believe you need to pry up slightly on the top and reach through the gap with a small screwdriver and press on the clips on either side to release the top and lift the top. Then there are two screws that hold the front to the sides and you should be able to lift the front off. Good luck.
Anonymous
  • Posted on Nov 07, 2010
SOURCE: Does anyone have the schematics or manual for a GE
I have this model with model#WSM2420TCAWW tag inside the dryer however the use and care guide and manual that came with it has Model#WSM2420S on it. Try searching this. If you dont have any luck I can send you a copy with your e-mail. Good luck dc
How to remove front panel on GE model GT65EBMK0DG dryer
GTD65EB - if this was your actual model number line, which you seemed to be missing, you need to take off the shoulder 1/4 screw in the back on the control panel, then remove the control panel pushing away fromy you, then your remove the two philips screws located under the control panel, open the dryer door, then remove the two philips under the lid, then move the lid back and then remove the two shoulder philips screws holding on the front of the unit. then pull the front of the dryer towards you, then remove the dryer front by pulling up, disconect the door switch wire, and the lamp wire on the top if yours has a door lamp. make sure its unplugged before attempting, if you have issues call GE appliance service for repairs.
Jan 14, 2019 • GE Dryers
Remove front panel ge spacemaker dryer
Here's the trick: The Spacemaker dryer is the same as many other GE dryers but is upside down!
1. Unplug the dryer.
2. Flip the dryer upside down so the white panel is now on top and the unfinished steel panel is on the bottom.
3. Remove the 2 screws that connect the bottom, white panel from the back and lift up to remove.
4. Pull off the Settings and Fabric knobs on the front of the dryer. Take off the front control panel (remove the 2 screws).
5. Remove the 2 screws that attach the front panel (located behind the control panel you just removed). Hold the dryer drum by the top edge and pull the front panel away (note that the panel will be hooked to the rest of the dryer at the bottom corners). DO NOT PULL AWAY ENTIRELY!
6. Disconnect the wiring that is attached to the front panel (these come apart easily by hand but you might want to mark the wiring so you know where to connect it when reassembling).
3helpful
How do i replace the door boot seal?
This article shows step by step photo instructions on how to replace the door boot seal of a common GE brand front load washing machine.
The washing machine in this example is the GE and the door boot seal
j
  • Phillips head screw driver
  • small socket wrench
  • 7mm socket
  • replacement door boot seal
  • lots and lots of patience
  1. replace-front-load-washing-machine-1.1-120x120.jpg remove dispenser Unplug washing machine and remove dispenser.
  2. replace-front-load-washing-machine-1.2-120x120.jpg Remove lower front cover by removing 3 screws holding it on bottom. Remove lower front cover by removing 3 screws holding it on bottom.
  3. replace-front-load-washing-machine-1.3-120x120.jpg Remove screws connecting top control panel to front of washer. Remove screws connecting top control panel to front of washer.
  4. replace-front-load-washing-machine-1.4-120x120.jpg Completely remove control panel from front panel. Remove 3 screws holding top panel on back of machine and slide cover back approximately 1 inch and lift off.
  5. replace-front-load-washing-machine-1.5-120x120.jpg Use bungie cord to tie back control panel. Use bungie cord to tie back control panel.
  6. replace-front-load-washing-machine-1.6-120x120.jpg 'Pop' off the tension spring being careful not to bend or break it. Feel for the tension spring which tightens the door boot seal onto the front panel.
  7. replace-front-load-washing-machine-1.7-120x120.jpg pull the right-hand side of the seal tight to reveal the inner tension ring holding the seal onto the inner part of the washer. With tension spring removed, pull door boot seal away from front panel.
    On GE models, pull the right-hand side of the seal tight to reveal the inner tension ring holding the seal onto the inner part of the washer.
  8. replace-front-load-washing-machine-1.8-120x120.jpg remove inner tension ring IMPORTANT: Use a short stem philips head (such as a Husky No. 2 x 1-1/2 In. Phillips Screwdriver) to loosen the inner tension ring via its clamp screw.
    NOTE: you may have to remove the front panel to gain access to the tension ring. If that is the case, remove the front panel by removing the screws positioned at each corner (four screws total). On some models you may have to first remove a lower-front panel to gain access to the bottom two screws of the main front panel.
Does anyone have the schematics or manual for a GE Spacemaker WSM2420TCAWW Stackable Washer and Dryer.
6helpful
2answers
Ge front load washer do not drain
Disconnect power to machine. Remove bottom front panel by removing one screw from each lower corner of panel. Have a few old towels ready to catch water, and remove clamp at pump inlet. Fish out all the coins or other objects from the rubber boot pump inlet. Reassemble and test with the panel off first. If all OK and no leaks, replace panel.
3helpful
How to disassemble a GE DBXR453EV0WW dryer?
Unplug the dryer.
Remove the screws from the control panel top rear.
Lift the control panel aside.
Pull the top lid forward to remove it.
Reach inside the right and left front corners to remove the screws holding the front panel to the cabinet.
Remove the door switch wires and set the front panel aside.
Your model may or may not have 2 screws holding the top lid down located inside the door opening. Open the door,get down on your knees and look up at the door opening for 2 screws.
Jan 03, 2010 • GE Dryers
2answers
How do I remove the front panel of a ge profile washer wprb8050d
That may not be possible; many units have connected front and sides that are removed as one piece by removing hardware in the back and inside the washer.
3helpful
Remove front panel on ge washer
Use a putty knife and press in the panel clips located on the top left and right sides where the front panel meets the top lid. They are about 3 inches in from each side.Press on the clips while pulling forward on the front panel.
Ge washer
remove top cover by 3 screws on rear then 3 screws in plastic control panel back. remove screws holding console on, lift up to remove, screw in dispenser area as well. remove lower kick panel and lower front panel screws. remove door lock screws and wire clip around boot. remove 2 upper front panel screws. there is another wire clip around boot at tub.
Top GE Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Virgil Watts
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
