Kyocera Color Copier, Km-c2525e Logo
A
Anonymous Posted on Sep 05, 2013
Touch screen not working
Kyocera km c2525e touch screen not working
4 Related Answers
Anonymous
  • 143 Answers
  • Posted on Jul 07, 2009
SOURCE: Kyocera KM-2050 scanner
You normally enter this information using your web browser and typing in the IP address of the scanner.
Hope this helps.
Anonymous
  • 66 Answers
  • Posted on Aug 16, 2009
SOURCE: copier km-c2525e will only print 1 page of document
Hi
it might be a long shot but have you got an add toner message on your copier screen.
When toner is required the copier will only print on page at a time.
Alternately you should ensure that you have not selected a partial print  eg
print current view or print current page.
if all this fails, reload the driver and or your Acrobat reader
hope this helps
cbtmaya
cbtmaya
  • 84 Answers
  • Posted on Aug 31, 2009
SOURCE: error code C-6 for kyocera km 1500
c6-400 code error is poor connection (power supply)
press start and clear/stop button
the code is inizialized
Anonymous
  • 241 Answers
  • Posted on Jun 09, 2010
SOURCE: I have a kyocera km 1820 copier at work and cannot...
The Kyocera KM-1820 does not have an automatic 2-sided option. This is why it cannot be found in the settings.
2answers
When i connect my kyocera km c2525e to the computer its picked as OEM 2JL-25C
Hello, connect your copier in a network and you can use the drivers from this page https://www.kyoceradocumentsolutions.eu/index/service/dlc.false.driver.KMC2525E._.EN.html
How can fix the error message c7104 in Kyocera c2525e
this code is saying you have a bad yellow dv unit you have to have a new 1
C2525e touch panel not working
Run a business card between the touch screen and the outside surround. Dirt or dust can make the screen believe that you are constantly touching the screen which will lock up the touchscreen. Try adjusting the screen brightness by adjusting the thumbwheel located at the far top of the display panel.
If this does not rectify the fault then the touchscreen will need to be replaced.
System error c0430
make sure RADF is connected
1helpful
How do I install driver for Kyocera CS 5035 on MAC
Kyocera and Copystar models are the same just replace KM with CS.
The following instructions should help you. TO download the current driver use this link to th emanufacture website; http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?rid=18657.
Kyocera Printer Drivers and Mac OS® X 10.5 Leopard FAQ:
Is the installation for Mac OS X 10.5 the same as for Mac OS X 10.4 and earlier? Mac OS X 10.5 introduced a new printing architecture that requires changes to the installer and installation process. For this reason, Mac OS X 10.5 requires a new printer driver installer.
I cannot see my Kyocera AppleTalk® printer. How can I make it visible to OS X 10.5? AppleTalk is disabled by default in Mac OS X 10.5. Enable AppleTalk to discover your Kyocera printer.If you use the Kyocera installer, a message will appear, asking you to enable AppleTalk. Click Yes to continue the installation.
I cannot find Printer Setup Utility on Mac OS X 10.5. Is it still supported? Apple has removed Printer Setup Utility from Mac OS X 10.5. To install a printer, open System Preferences and click Print & Fax.
When I manually install a printer, multiple PPD files are listed for the same Kyocera model. Which should I choose? When manually installing a printer or changing a PPD for a installed printer, both Linux and Mac OS X PPDs are listed for some older Kyocera models due to a change in PPD handling in Mac OS X 10.5. Linux PPDs can be identified by the word Gutenprint in the PPD filenames.
Supported Multifunction Printers: KM-1650, KM-1815, KM-1820, KM-2050 ,KM-2530 ,KM-2550, KM-3035, KM-3050, KM-3530, KM-4030, KM-4035, KM-4050, KM-4530, KM-5035, KM-5050, KM-5530, KM-6030, KM-6330, KM-7530, KM-8030, KM-C830, KM-C830D, KM-C850, KM-C850D, KM-C2520, KMC2525E, KM-C2630, KM-C3225, KM-C3225E, KM-C3232, KM-C3232E, KM-C4008, KM-C4035E, CS-1650, CS-1815, CS-1820, CS-2050,CS-C2525E, CS-2550, CS-6030, or newer. Supported Printers: FS-820, FS-920, FS-1018MFP, FS-1020D, FS-1030, FS-1100, FS-1118MFP, FS-1300D, FS-1800, FS-1800+, FS-1900, FS-1920, FS-3800, FS-3820N, FS-3830N, FS-6020, FS-6026, FS-9100DN, FS-9120DN, FS-9500DN, FS-9520DN, FS-C5016N, FS-C5020N, FS-C5030N, FS-C8008N, FS-C8026N, FS-C8100DN, or newer.
I hope this is helpful,
Shawn
Copier km-c2525e will only print 1 page of document
Hi
hope this helps
Top Kyocera Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Ngoro
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
