eMachines T3656 Celeron 440 1GB DDR2 160GB Intel GMA 950 Windows Vista Home Basic PC Desktop Logo
R. A. Bradbery Posted on Sep 06, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
EMachine W3507, will not boot after adding 2GB of memory. (2x 1GB; one in each slot). It will boot with one stick, but only if the original 512MG is in slot 1. The 512MB is not recognized.
  • Brian Sullivan
    Brian Sullivan Sep 06, 2013
    Installed Size 1.0 GB / 2.0 GB (max) . Technology DDR2 SDRAM
Brian Sullivan
Level 3:
  • eMachines Master 27,725 Answers
  • Posted on Sep 06, 2013
Brian Sullivan
eMachines Master
Level 3:
Answers
27725
Questions
Helped
5664270
Points
79191
Where they purchased as a working pair some motherboards will only accept working pairs>?
Make sure RAM modules are of same brand and type try one ram module at a time in the working slot closest the cpu if both work individually they are not a working pair
4 Related Answers
Anonymous
  • 565 Answers
  • Posted on Jan 28, 2009
SOURCE: Upgrade problems
Your system comes stock with one stick of DDR2 (512 MB), which means that it is _ not_ dual channel DDR2 memory as dual channel DDR2 must be installed in matched pairs. Try to exchange the new memory for 2G of some single channel DDR2.
Anonymous
  • 57 Answers
  • Posted on Nov 10, 2009
SOURCE: does my w3507 have an agp port
I found the specs below on their website. Sorry only a PCI Enhanced port, NO AGP. Hope this helps. Best Regards, -md CPU : Intel® Celeron® D Processor 352
(3.20GHz, 512KB L2 cache, 533MHz FSB) Operating System : Genuine Microsoft® Windows® XP Media Center Edition 2005 Monitor : Includes eMachines® 15.4" Widescreen LCD Flat Panel Monitor Chipset : ATI Radeon™ Xpress 200 Memory : 512MB DDR2 (1 × 512MB), 533MHz (PC4200)
Expandable to 2GB Hard Drive : 120GB HDD (7200rpm, 2MB cache) Optical Drive : 16x Multi-format Dual-layer DVD±RW Media Reader : 9-in-1 Digital Media Manager™ (Memory Stick®, Memory Stick Pro®, MultiMediaCard™, Secure Digital™, CompactFlash®, MicroDrive, SmartMedia, xD-Picture Card™, USB 2.0) Video : ATI Radeon™ X200-based integrated graphics
Up to 128MB of shared video memory
PCI Express (PCIe x16) slot available Sound : 6-channel (5.1) high-definition audio Network : 10/100Mbps integrated Ethernet LAN (RJ-45 port) Modem : 56K ITU v.92-ready Fax/Modem (RJ-11 port) Peripherals : Standard multifunction keyboard, 2-button wheel mouse, amplified stereo speakers (USB powered) Ports/Other : 5 USB 2.0 (1 in front, 4 in back), VGA External Connector, serial port, parallel port, 2 PS/2 ports, 5 audio ports (2 in front, 3 in back) Dimensions : 14.25"H x 7.25"W x 16"D Weight : 22.5 lbs
FYI - PCI Express (Peripheral Component Interconnect Express), officially abbreviated as PCIe (or PCI-E, as it is commonly called), is a computer expansion card standard designed to replace the older PCI, PCI-X, and AGP standards. Introduced by Intel in 2004, PCIe is the latest standard for expansion cards that is available on mainstream
E-machine w3507 specs:
Expandable to 2GB
Weight : 22.5 lbs
TechyDrood
Justin
  • 2072 Answers
  • Posted on Sep 10, 2011
SOURCE: added 2 1GB memory to
There are two variants of the T5048 One uses DDR PC3200 ram the other uses DDR2 PC5300
Should be able to look at the old ram and it should say on it what it is. If it doesn't, take out the new, put in the old ram and go here http://www.crucial.com/store/drammemory.aspx Run the "Scan My Computer"
Some computers will have a setting in BIOS to disable on board video although eMachine are very low end and probably don't offer that. Shouldn't need to just install your video card and plug your monitor into it. It should work just fine without disabling on board.
Comment if you need more help
bronk50
Brian Sullivan
  • 27725 Answers
  • Posted on Nov 05, 2012
SOURCE: emachine w3507 powers on but will not boot up
Ram modules might be dirty or dirt in ram sockets
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards
Remove the memory modules from their slots.
Take the opportunity to clean the slots on the motherboards and the memory module connectors.
Use compressed air to blow dust away and clean contacts with a soft cloth.
Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components.
hope this helps
Fujitsu v700 4 gb memory will not boot
You don't say if the Notebook is 32 or 64 bit.
If its 32 you may have a problem uprating the RAM more than be handled.
I recently purchased Two PNY 1Gb ram to upgrade from original 512mb. When I put both 1Gb ram in the slots, the computer will not boot up. When I take one out and put the original 512 back in with the other...
I don't know your specific model, but some of the Emachines had some memory directly on the motherboard. With the 1Gb and 512Mb sticks installed, boot the machine and report how much memory the system sees. Perhaps the onboard memory is causing you to exceed the 2Gb limit.
Please post the memory size you get here with the above sticks.
Thanks,
Dan
I added an additional 1GB of RAM card , but my computer will not recognize the additional memory. I tried swapping cards between the two slots , nothing . The specs say the motherboard can handle 1GB per...
If you have the additonal memory in the system correctly, it should be recognized.
Attempt to boot the system with just the new stick in. If it boots you most likely have a motherboard issue. If it doesn't, it's just a bad stick of memory and I suggest just getting a new one.
Just installed 2 2GB cards (Corsair VS2GB800D2) to replace the 1 1GB card in my emachines EL1200 series. Computer will not boot. replaced the old card and it booted right up.
Will it boot with only ONE of the 2GB memory-sticks installed?
Will it boot with ONE of the 2GB memory-sticks AND one of the 1GB memory-sticks?
Look closely at the 1GB memory-sticks.
Does the label show 'DDR266' or 'DDR333' or 'DDR400' or 'PC2100' or 'PC2700' or 'PC3200' ?
Do the 2GB memory-sticks have _identical_ information?
It's definitely _not_ acceptable to have "slower" RAM (smaller numbers) in the new RAM,
but it _might_ be acceptable to have "faster" RAM (larger numbers).
2answers
Does my w3507 have an agp port
No it does not have an agp port. IT has a PCI Express Port for video cards. Its much better and faster.
Details on your machine and what it has can be found at this link. Hope it helps.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2912877&CatId=2643
1helpful
Adding memory, new total not recognized: IBM Thinkpad R51e-1844
Ram should always be paired. Same type, speed and size in each slot. You may have 1 SIMM/DIMM/DDR that has 2 sides of chips and the other with 1 which will do exactly what you state. RAM reads across the chips simultaneously. So if you have a different one in each slot it can go bonkers and do goofy stuff on you.
Cant install full 2GB of memory in my emachines t3990
try removing the cmos battery and put it again and booting up.. since you have bought same kind of ram i dont think it could be a problem.also check for the jumpers in *********** board where you can reset your bios. be sure to read *********** boards manual before this
Upgrade problems
2helpful
Installing 2GB of memory in my Fujitsu Siemens Amilo Pro V2020
Here is the problem, the laptop take 2GB RAM. 1GB in each slot, so get 2X1GB RAM. They are cheap now. You need 2, 1GB sticks of ram. For cheap prices go to Newegg.com
Have a nice day!
Top eMachines Computers & Internet Experts
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
