LG LFX25960ST Stainless Steel French Door Refrigerator Logo
A
Anonymous Posted on Jun 02, 2017
Display Panel Dark and Not Working
We have a LG LFX25960ST and the control panel seems to have gone out in it. We have tried unplugging the fridge anywhere from 30sec to 30min with the same results. At power on all the buttons light up for a second and then the lock button lights up and then goes out after about 10 seconds. No LED display ever comes on and then the panel is just dark and nothing works. The fridge still cools and freezes but only water works out of the unit as we cannot switch to ice. Any help here?
1 Related Answer
Anonymous
  • 1056 Answers
  • Posted on May 28, 2011
SOURCE: My LG refrigerator is not working. The interior
Keep it plugged in it might start working after it reset itself.
LG Fridge GS-L668PNL (Control Panel-Display) not working
It is possible that the issue is with the control panel (display) itself, as you have ordered a replacement. However, before installing the new control panel, you should check the wiring connections and make sure they are secure and not damaged. You should also check the electrical supply to the fridge to ensure that it is functioning properly. If the issue persists after installing the new control panel, you may want to consider calling a professional to diagnose the issue.
Lg lfx25960st refrigerator not turning on
Bad control board check for fuse or relay on main circuit unplug unit first
1helpful
Control panel on front stops working, only freezer lights are lit, freezer and fridge stop cooling.
when half of the display goes out, it is giving you an error code telling you what is wrong with the fridge.Unplugging it simply resets the computer until the error comes back typically within a few hours.
without knowing what is lit up, it is difficult to help you so I would recommend putting the error code "which bars are lit up" in a comment so we can diagnose further
2answers
2answers
Regrigerator shows error code 1F
Hello tr-6
Welcome
You Wrote,
LFX25960ST LG FRENCH DOOR REFRIGERATOR DATE OF PURCHASE 7-7-07 DELIVERED 7-13-07 ICE MAKER REPLACED ABOUT THIS TIME LAST YEAR AFTER TWO MONTH WAIT. NOT PLEASED WITH PERFORMANCE OR SERVICE TO DATE. REQUEST THIS PROBLEM BE COVERED BY WARRANTY.
Below is the service manual And the explanation for your error.
Thank You for using our site.
Huuum
Please remember to leave a solved rating.
Error Detection Category
ERROR CODE : IF
Abnormality of
BLDC FAN Motor
for Ice Making
Error Generation Factors
It is caused when F/B
signal isn’t over 115
seconds during BLDC
FAN motor operating
Remark
Poor BLDC Motor
connection, DRIVE IC, and
TR
Resource reference located here:
http://136.166.4.200/contents/Fridge/LFX25960/LFX25960_Service_Manual.pdf
Huuum
3helpful
2answers
Error Message: Er dH
The error codes are listed in the service manual (p. 32) at the address below:
LFX25960 Service Manual
"Er dH" seems to be a defroster issue.
Control panel
I had the same problem....3rd problem for this fridge...the tech is coming out , he said it is the icemaker. I will let you know after he fixes the problem.
2answers
The control panel light blinking and ice trap door will not close
Sounds like you need a new display pwb. The flapper for the ice works on a solenoid which is on a little board that is behind the display board. When the power is cut the flapper should close as it is on a spring. I don't believe that there is any worries of it catching fire. Have a tech come and replace the board for you.
Sgt 48
Top LG Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
