Columbia All Sport Digital watch Logo
Posted on Apr 14, 2009
Need instructions to change the time, can't find mine
Time change directions for columbia watch cl-5017
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 17, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1489
Points
11
2helpful
I can't find a cl 5017 battery for my Columbia watch.
cl 5017 is not a battery code or size, try bring your actual battery or your watch on watch service centers. they probably have your battery.
1helpful
I can't open the back of my columbia sportsware CL-7017330 feet water resistance watch. I need to change the battery.
To be honest, I would send back to Columbia. Water resistant watches are not only tricky, but you risk losing the warranty on your watch as well.
I would go to link and follow instructions:
http://www.columbia.com/FAQ-Details/CustomerService_FAQ_QuestionDetail,default,pg.html?rnurl=/app/answers/detail/a_id/417/session/L3NpZC9JRmxoZVk3aw==
Columbia ana-digi watch model CL-3209, how to change day of the week?
Go to "www.columbia.com/Equipment-+-Accessories/Licensee_Landing,default,pg.html"
Under "Timing" you will see a link "PDF.............", click on this
and a list of diagrams will appear. Choose the one that looks like yours
and follow the adjacent instructions.
Mar 20, 2010 • Watches
Columbia CL-5008
If you need instructions then go to "www.columbia.com/Equipment-+-Accessories/Licensee_Landing,default,pg.html"
How too turn off hourly chime on columbia cl-5017 watch
Under "Timing" you will see a link "PDF.............", click on this and a list of diagrams will appear. Choose the one that looks like your and follow the adjacent instructions.
Feb 08, 2010 • Watches
1helpful
The columbia site has no timing instructions.
Instructions can be obtained by going to the Columbia web site "columbia.com".
Insert "watches" in the search box (top right) and the next page shows a watch with the title "timing" and underneath in says "PDF instruction manual for watches"
Click on this and a list of diagrams for the watches appears. Choose the one that is for your watch and down load.
2helpful
How do i change battery on columbia 5017
Open watch caseback. Undo the contact covering the battery. Read the writings on battery and buy exactly the same one. Get the old battery out and replace with the new one exactly the same way as it was. Redo the contact. Put caseback back on. Reset the watch.
Rate, please.
1helpful
Chime not working on a Columbia CL-5017
This is because you lost the coil spring when battery change took place. Coil spring works as a conductor to the membrane inside caseback and transmits the signal. If you can not find it, you will need to find your nearest watchmaker and ask for new coilspring.
I am pretty sure that you think you did not lost anything, but I can assure you that you did. Coilspring is very tiny and hard to see when dropped and you can not hear it as well.
In case if you find that spring, you have to open the watch and put it back in. There is a small hole in the watch movement and it is designed for coilspring.
Rate me, please.
Top Columbia Watches Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Samuel Osungbohun
Samuel Osungbohun
Level 1 Expert
Are you a Columbia Watch Expert? Answer questions, earn points and help others
