SOURCE: My fax machine stays on and I can't print
Try this.. Go to start, devices and printers and you will have a few things listed in there that are related to your printer. Most likely it will say document writer, fax and your hp printer. Make sure that the check mark is on your printer, not your fax. This indicates what your default printer is. To change this, right click on your hp printer and select set as default printer. Once this is set try printing again. Let me know if this works, if not we will try step 2. Hope this helps!
SOURCE: My Hp officejet 4255 all
Hi There,
Thanks for you using FixYa.
The problem can be solved by repairing Motor/Roller.
It needs to have a shaft at both ends (dual shaft), and it takes some
soldering and replacement of the black round plastic gizmo with tiny
fingers around it back onto the shaft of the replacement motor as well
as the tiny worm gear and the little green circuit board (has to be
soldered onto the new motor).
You can order it cheaply at www.allelectronics.com and specify the above motor model but be sure to select the dual shaft one.
Regards
Ellin
Ell
SOURCE: ihave a hp officejet/hp officejet
I think there is a removable panel in the back that has a large knob to open.
