I dont know how to turn on the olympus d-390 digital camera i cant find the on button
Open the Lens barrier to turn the camera ON and by closing the Lens barrier, you will turn it OFF.
Please let me know if that helps..
Thanks and Regards,
Srinivas
Assuming that the camera worked earlier and it did not fall from a height...
Make sure that the batteries are inserted with the correct polarity.. There is a mark on the bottom of the camera showing the correct way to insert batteries. To maximize battery life, this digital camera features a power saving mode in which the camera enters a sleep mode after approximately three (3) minutes of non-use. Press the shutter button to wake up the camera.
Try removing the Memory card if any inserted.
And if the monitor does not come on even after that then the last thing we can try to make sure that the problem is not with the battery power supply is to try connecting external power supply (Camera has an option for connecting DC 3.4V Jack).
And if still the monitor does not come on then consider giving the camera to service center for repair.
Regards,
Srinivas
its open but the screen is blank
