I purchased compaq notebook CQ45-207TU. As per the recommendations of HP I upgraded BIOS and after that the fan is constantly running fast and the touch pad also gets heated. However one of my friend has installed an old version of BIOS(of which i am not sure the factory installed BIOS). At present the fan has stopped going fast however it runs after an interval of 10-15 minutes. Pls post solution at [email protected] . Also if you could provide me the original factory BIOS version.
The present version installed is;
OS Name Microsoft® Windows Vista™ Home Basic
Version 6.0.6001 Service Pack 1 Build 6001
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name COMPAQ-PC
System Manufacturer Hewlett-Packard
System Model Compaq Presario CQ45 Notebook PC
System Type X86-based PC
Processor Intel(R) Pentium(R) Dual CPU T3200 @ 2.00GHz, 2000 Mhz, 2 Core(s), 2 Logical Processor(s)
BIOS Version/Date Hewlett-Packard F.24, 24-11-2008
SMBIOS Version 2.4
Windows Directory C:\Windows
System Directory C:\Windows\system32
Boot Device \Device\HarddiskVolume1
Locale India
Hardware Abstraction Layer Version = "6.0.6001.18000"
User Name compaq-PC\compaq
Time Zone India Standard Time
Installed Physical Memory (RAM) 2.00 GB
Total Physical Memory 1.96 GB
Available Physical Memory 935 MB
Total Virtual Memory 4.16 GB
Available Virtual Memory 2.60 GB
Page File Space 2.26 GB
Page File C:\pagefile.sys
Rgs,
Karvender
You bios versions start at f.03,f.04,f.05, f.07, f.08,,,
The date and version that you posted does not match and bios version for your model.
The only reason you update a bios is if it falls under the problems
listed for the new bios to correct.
Say your lap came with f.05, the only reason you would update to f.07 is because you had a graphic error,that the new update fixed.
The link below is the page for your drivers, if you look at bios,it shows the newest,if you click on version,you will see all the ones
that where made.
You should double check to make sure that you have the right bios version.
http://h10025.www1.hp.com/ewfrf/wc/previousVersions?softwareitem=ob-61399-1&lc=en&dlc=en&cc=us&lang=en&os=2093&product=3646603
I need to find a bios update for this model, Currently running windows 7, a bit glitchy. New harddrive. Current version and processor is hp f27 10 9 2009
amd anthlod neo mv40 1600 mhz 1 core
