Water goes into the washer even when the washer is off
From the second I turn the water valve on my front load whirlpool duet ghw9100lw2 water starts filling the machine even when it is off. is it the water intake valve?
After a wash cycle water is pooled in the drum and clothes are soggy. Ran a rinse and drain cylce and removed clothes immediately. Water seems to pool in the drum again slowly.
You can't post conmments that contain an email address.
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath.The panel will drop and come off.Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.Check your pump too, comes after the filter.
At Lowes you can purchase foam rubber pads 4"X5" pack of two for $3.50. If walking forward and after cecking level and washer pads are tight, place half of one pad under each of the two front feet. Place the sticky side against washer feet. Solved my problem.
Washer should fill, remove hoses, check screens in hoses and or valves on machine for clogs. Verify water valves at the source are turned on. If all this checks, you need new valve installed on your washer.
first make sure the hosesaren't reversed hot on cold or cold on hot next turn off cold water remove the hose from the washer and check to see if the screen on the washer is clogged if not get a bucket turn on cold water and see how strong the water is then let me know what you find dont rate me till we are done
thank you so much
