SOURCE: fridge is not cold and freezer is not cold
the vents might have glogged by some thing or maybe there is some airleaking from the doors and preventing the freezer to reach the necessary freezing temprature.check out.
I need you to double check the model number. Maytag has a service library at this link. http://www.servicematters.com/maytag_library/html/index.html
By placing the first 3 letters in the search feature it will take you to models like yours. Chose the correct model that you have and enter the number in the search. I believe that the water control valve on back of your refrigerator is the problem. Maytag is very good about helping their customers. Let me know if you have problems gettting the information you need, Thanks, Sea Breeze
SOURCE: Ice maker sprays water...
sounds like the inlet part on the ice maker is froze over or not lined up in the opening of it right or a possibilty that the ice maker is leaking out the water if that is the case the ice maker needs replaced
SOURCE: plastic ice dispenser cover in freezer door
The door part # is 61005883 and the strick which holds the door is part # 61005886
SOURCE: lights on panel blinking. ice dispenser keeps opening and closing
there is the HV board on the back under a cover . 2 680uf capacitors @ 35v are likely domed instead of flat on the top and are likely hot. replacing these with an equal value will cure the problem. they are in parallel so 1000 and 470uf will cure it. mine was same model except white. local dealer said no warranty. did not call maytag but he indicated it might help. good luck
Hello friend, thank you for your inquiry!
If your Frigidaire refrigerator is not dispensing ice you could be seeing a problem within the dispenser or auger motor not pushing ice. If you press on the dispenser do you hear any noise? Also can you check inside the freezer door verify no frost or ice is blocking the dispenser door? I look forward to assisting you. -Matt
