SOURCE: When i try to use
Error 1106 is an indication that the Domain Name System
(DNS) was unable to resolve. Follow the steps to check the Internet
connection:
If any of the connection settings fail, verify that the TV is properly connected to an active Internet connection.
Follow these steps, if the error continues to appear:
Testimonial: "Thank you very much for helping me. Your solution was very helpful !!"
SOURCE: what is sony error code 1106. On selecting the
Solution proposed by Soufane (member of the Fixya community) :
Error 1106 is an indication that the Domain Name System (DNS) was unable to resolve. Follow the steps to check the Internet connection:
SOURCE: I could not connect to
Ethernet connections between the tv and the computer into one signal frequencies are not compatible signals.Ur main home computer have internet service connection go through a wire or wire less Router for a internet signal through out the house.Connect the tv internet signal through the Router.Internet signal will work fine.
