SOURCE: dies running wide open
Hi
Check the air and the gas filtetrs.Change the plug with a new one with the same heat range.Adjust the carb H and L.
High speed H=2 turns and low speed L=2 1/2 turns
best regards savumihai71
SOURCE: I have a 36cc poulan chainsaw and it runs but not
I would go to Poulanpro.com with your model number and take a look at the manual for this tool and it gives you some troubleshooting hints on carb adjustments and other items to look for.
SOURCE: homelite saw runs wide open(homelite ut10520)
There is a recall on the UT models, all you have to do is call the costumer service center for homelite. they will give you a number for the closest warrenty center that will adjust you throttle cable free of charge. I went through two UT 10520's before i started researching the problem.
SOURCE: starts and then runs wide open.
SOUNDS LIKE THROTTLE NEEDLE STUCK OPEN CHECK THROTTLE LINKAGE STICKING OR RETURN SPRING
SOURCE: my 455 starts good and idles fine but wont go wide
Husqvarna recommends 50:1
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
Lou
Clean the air filter and spark arrestor (muffler)
Try turning the "H" sdrew 1/8 turn CCW, if no better 3/16 CW.
this explains needle valve adjustment better than anything else I have seen.
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too. HTH
Lou
