For this model specifically, the following will get you into service mode.
Hit "Clear / Stop" Buttom then "107" then hold down "color print" buttom for some sec then you are in service mode
If that doesn't work, you can also use Clear/Stop,1,0,7, Clear/Start.
Each key should be pressed and held until you hear a beep
SOURCE: Ricoh Aficio SP 420dn shows SC542 error code after
Hi dear pls take you printer to service center
Thank you
Imran
Pls rank as possible have nice day
SOURCE: i have a ricoh aficio sp c420dn, when and turn on
You may try first to reset the SC 542 before calling a technician!
That you can do by following method:
1.Turn the machine off and then after 5 second turn it on while pressing the “On Line” key and “Escape” key together until “SYSTEMver x.xx/1. Service” shows on the display.
2.Use the “Up/Down arrow” keys to scroll through the menu listing.
3. Press the (OK) key while on the display writes " 2. Engine " .
4.go to "[5810 001] - Fusing SC Reset" by scrolling the “Up/Down arrow” keys and press the [OK] key (on the display should write execute or done) press [OK] again if is needed to press it.
5. After this turn off and than after 5 second turn it on the machine.
Please do not change nothing else in this menu only reset the fusing unit SC code, because if you change some other values and settings you might to regret that and pay high price for that.
So only reset the Fuser SC code SC542 by the upper mentioned method and do nothing else, if the SC code appear again then do not try this again because you might burn some parts.
If this do not help than call the technician.
Please answer do this is helpful for i to know do the problem was solved.
Regards
SOURCE: Ricoh Aficio SP C210 error message
Try loading letter size paper in tray1 .. Open the front door and the assembly attached to the front door is the transfer roller ASM. mybe you knocked it out of position ..There are green plastic clips that allow someone to the transfer roller unit so its easy to mess up good luck
SOURCE: Hi, I have a Printer
This error code means temperature fusing problem. Check all of the connectors on the fuser connector and receptacle, just to make sure that full contact is being made.According to Ricoh direct techs after 100K to 200K copies on a new machine the Hot Roller would start to warp (ever so slightly) because of its thin wall construction (fast warmup time).Replacing the Hot Roller will solve the problem.Please don't forget to rate me if satisfied.
