Question about Kenwood Excelon KAC-X521 Car Audio Amplifier
MY kenwood amp is reading E-03 any solution to that
My amp is flashing a red light the fan stop and then i unpluged everything and then wired everything back together and it jus flashes a red light and and sign called E-03
My amp is flashing e-03 messege i checked all the wires to see if they are grounded in any way. i rewired the whole system and it seems to go out whenever i turn up the volume. i dont know if its my speakers that are blown or my amp is messed up,
  • 578 Answers
Check speaker and power source
Posted on Aug 07, 2009
6ya staff
SOURCE:
I have a fisher & paykel active smart fridge the fridge part freezes everything and wont stop beeping when door open
Your fridge is telling you there is a fault, i'd say one of the 2 fans are not working. If everything is freezing in the bottom of the food compartment then the upper fan is faulty. You have to remove the shelves & remove the rear panel, the fan is in the shute at the bottom, remove, repair the broken wire or replace. Make sure unit is unpluged.
Aug 10, 2014 | Fisher and Paykel Active Smart E522B...
Ws-65313 no power unless it's unplugged first
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Jan 23, 2008 | Mitsubishi WS-65313 65" Rear Projection...
RED FLASHING STATUS LIGHT
Possible lamp failure but lamp light not status should blink-I have suggestions but want you to try the self check first--if set has been unplugged plug it up and turn on and when it fails:
Mitsubishi TVtroubleshooting
Here's something that might also be useful. After you turn on the set, and getthe regular red blinky lights, hold down the Device and Menu buttons togetherfor about 5 seconds.
33 = Air filtercover is open.
44 = DVI cablebetween FMT and Engine disconnected
Jun 11, 2012 | Mitsubishi WD-62525 62" Rear Projection...
We have a mitsubishi WD-62525 tv and we turned it on and after a while it turned itself off and then we got a continiously flashing red status light! what does this mean & what do we need to do to fix...
I have a wd65100 when powered on i get steady orange light then status blinks red & green,unpluged for 1 hour tv is working but dark picture
Hi
This issue can be due to ballast fan, lamp or high temperature. However, to figure out this we'll need to check for the TV from inside(wiring & testing the components) or the other way is when the lights blink again then follow the procedure given. After you turn on the set, and get the red blinking lights, hold down the Device and Menu buttons together for about 5 seconds.
For example, 4 flashes, then 1 flash = 41.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jul 28, 2009 | Televison & Video
Mitsubishi WS 55809
Feb 15, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Power up problem
Hi, you most probably have a sticky on/off switch on your case. Turn the power off. Remove the side cover, trace your wires from the front switch to the mobo, identify witch is the power switch [this is usualy marked with PWR or PWS on the board and also on the wire from the switch. Disconnect this wire then turn on the power and use a fine screwdriver to bridge the two pins on the board, if all works properly then replace the switch Regards mistyman
Sep 06, 2007 | E-Machines eMachines T3830 PC Desktop
Hifonics 1605d stopped working
the red light blinking because your amplifaier its dead look for the alimentation cabel end replace the calibration protector
Apr 16, 2007 | Hifonics BX1500D Car Audio Amplifier
Kenwood Excelon KAC-X521 Car Audio Amplifier Logo
359 people viewed this question
Top Kenwood Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
