Me id use google earth to locate there service center (where it got sent to repair )and then see there (elevation) if it exceeds 3k feet (I suspect it might) then id gather this info and send it in a nice letter to your states attorney general for fraudulent claims , im betting one letter of intent to pursue consumer ***** from them to dewalt and you'll see a differnet outcome !!
SOURCE: I need a mamnual for a dewalt dw567 type 1
dewaltservicenet.com
enter model in "find it now", click on the spyglass
click on type,
left side navigation should give option for both parts breakdowns and instruction manuals
SOURCE: have a problem with bosch brute jackhammer, quit
did you check the cord first? after that I would check the brushes and make sure the switch wired correctly. Let me know if you need more assistance.
SOURCE: dewalt demolition hammer stopped hammering.
could be a few problems, the striker could be stuck from debris or the ram might be hydraulically locked. they make a rebuild kit for this tool if you are mechanically inclined. I would suggest first going to their site and downloading a parts breakdown and there you will find what is involved and the parts listing. It is "dewaltservicenet.com" and on the left hand side type in your model number and then follow the links to download this. Let me know if you need more assistance.
SOURCE: The chuck on my old
You are more than likely missing the chuck retaining screw. If you give me the model number I will get you a part number and info on how to order. It is a left hand screw.
SOURCE: Dewalt demo hammer, when switched on the motor speed surges up and down constantly. What is wrong?
Check the brushes first. If they are worn or sticking they could cause this.
If the brushes are fine and not worn down then it is most likely the electronics/ variable speed module.
