My kitchen aid bottom drawer freezer kept melting and freezing to block the drain and then water would leak out all over the floor. I did the WHOLE fridge/freezer defrosting process once, when i really just needed to do the bottom.
I have had issues with other Kitchen Aid (NEW BTW) appliances so I've talked to many repair people. One guy who came out to fix something else, told me that the freezer is really a pain to get to close completely. SO, when you don't close it all the way (Extra push) it will melt and then re freeze when it is closed properly. He suggested I take everything out, leave it open and use a hair dryer on the ice until it melts. Then use a wire hanger to unplug the drain to make sure its draining properly.
It works! You really have to make sure the drawer is shut ALL the way. I have a 2 yr old who is constantly opening it up...this is my issue! The seal is not that great and you have to really push it closed to prevent the ice build up issue.
Hope that helps!
SOURCE: Kenmore Elite Bottom Freezer Mod. #795 75544401
The unit was built bt LG. It is a computer controled unit and the timer is built into the main control board on back of the unit. However, the most likely cause of the broblem is the defrost terminator located on the evap on the upper right hand corner. Also, try unpugging the unit it will reset the computer board. You will also have to defrost the unit.
SOURCE: fan runs constantly, freezer ice melting, bottom drawer in refrig
SOURCE: Kitchen Aid KSRP25F Ice Maker
The ice maker is not working, no ice ice is coming in the tray on my Kitchen Aid KSRP25F Refridgerator, the red light keeps on
blinking
Del
