Panasonic DVD-LA95 Portable DVD Player Logo
Posted on Apr 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
REGIONAL ERROR When i put a dvd disc in my Philips dvp 3046 it says Wrong region after loading..Please suggest me a solution to this problem. Thank you in advance..
Anonymous
Level 2:
  • Expert 50 Answers
  • Posted on May 20, 2009
Anonymous
Expert
Level 2:
Answers
50
Questions
0
Helped
34593
Points
156
You can make it regioncode freefollowing these steps..
1. Press "Setup" and go to "PREFERENCES" (DVD stopped and player opened)
2. Scroll to "PBC" using the LEFT/RIGHT arrow key
3. Press "138931" and a pop-up screen will appear.
4. Use the UP/DOWN arrow key to choose the desired number. ( 0 for regionfree!!)
Jay
Ken Kichi
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 150 Answers
  • Posted on Apr 15, 2009
Ken Kichi
Expert
Level 2:
Cheetah:
Night Owl:
Answers
150
Questions
Helped
34718
Points
275
Try hitting #1 on your remote repeatedly, sometimes that'll bypass the regioncode and allow playback w/out the menus to work.
Anonymous
Level 3:
  • Master 432 Answers
Anonymous
Master
Level 3:
Answers
432
Questions
0
Helped
197663
Points
1334
If you right click on my computer --> properties --> hardware tab --> device manager --> go down to the optical drives / dvd drive and right click on your dvd drive and go to properties there should be a region tab.
change the region to the correct region or use vlc
http://www.videolan.org/vlc
Philips DVD player DVP3996 is giving wrong region error
Hello
To set your Philips DVP region free, do the folloing.
Press "Setup"
Scroll to "Preference" using the Left/Right arrow key
Press OK
Press "138931" and a popup screen will appear
Use the Up arrow key and select Region 0 for a region free DVD player
OK.
2helpful
2answers
How do I unlock my Sony DVP - NS330 player, bought
Codes for-
Sony DVP-NS300, Sony DVP-NS305, Sony DVP-NS400D, Sony DVP-NS700, Sony DVP-S330, Sony DVP-S335, Sony DVP-S360, Sony DVP-S336, Sony DVP-S525D, Sony DVP-S530D, Sony DVP-S535D, Sony DVP-S536D, Sony DVP-S725D, Sony DVP-S735D
Turn on the unit with the remote controller, Wait until "no disc" appears in the unit's display. Press the keys: PAUSE, 3, 1, 4, 1, 5, 9. And "CODE" will appear in the display. Press the number key that corresponds to the disc zone you want to play within the next 5 seconds:0: All regions / 1: Region#1 / 2: R#2/... and so on. Then, within 5 seconds, press: PAUSE, POWER... and voilà. If you don't have good results, disconnect the equipment and repeat.
Or
Put your player in standby mode and then enter: [[0] [ENTER] Default Default region code [1] [ENTER] or [UP] [ENTER] Region 1 [2] [ENTER] or [RIGHT] [ENTER] Region 2 [3] [ENTER] or [DOWN] [ENTER] Region 3 [4] [ENTER] or [LEFT] [ENTER] Region 4 [5] [ENTER] or [TITLE] [ENTER] Region 5 [6] [ENTER] or [DVDMENU] [ENTER] Region 6 [7] [ENTER] or [RETURN] [ENTER] Region 7 [8] [ENTER] or [DISPLAY] [ENTER] Region 8
Or
Put player into standby modes by pressing power button on remote control. Then press Title button. Press Clear button. Press Power button.
Yours is not listed but these may be worth a go.
or try http://www.haldigital.com/hp/dvd.htm
2answers
" Wrong Region " error displayed while trying to play DVD's
Most branded DVD's have a country code programmed in it.
There is no code to reset it.
It is better you buy a local chines make kinda dvd palyer. It will play all and comes cheap.
Cheers
TeaCii
If you own website, add live support almost free
Real security guard to watch your cctv for $1/day
I HAVE A DISC IN U.K. AND EUROPE REGION . BUT CAN'T PLAY MY DVD PLAYER. HOW CAN I PLAY THE DISC IN OUR PLAYER? MODEL IS DVP 3256 ,DVP 3258,DVP 3268 . WITH USB . ANY OPTION TO PLAY THE OTHER REGION DISC....
HELLO
This sounds like the old problem of your player trying to play a disc from another region, when your player is set for another. What you need to do is HACK the player and set it for ALL REGIONS (0), usually via the remote control.
Try this website for DVD player hacks: www.videohelp.com
You will find hacks for many makes and models listed here. Contrary to belief, it is NOT illegal to hack a DVD player.
2answers
Wrong region
hi!your english is good!!
please try this:hope it helps!
dvp720sa
dvd player on
open tray
(no disk inside)
1. Turn on the player.
2. Open the tray.
3. Press the following sequence on the remote: 9-9-9-9-0
4. The number 0 will appear on the lower left side of your screen.
5. Your player is now region free! Put in a DVD and enjoy!
NOTE: The 0 in the sequence above represents the region code. 0 = region free. If you want to change your player to just a specific region code, replace the 0 with the region number you want.
1helpful
Philips DVP 3020 says 'no disc' when you try to load any disk including a cleaner
ewaltercat,;
I guess the problem was in internal., you try to open case and while operated with disc watch if the optical lens working, may also try to open region code to "0" or multi region
posible problem "NO DISC"
a. Optical Lens
b. FCC wire
c. Mpeg Board
d. Wrong Region
Regards
Clyde Acenas
2helpful
Wrong Region message
This will make the player region free so it'll play anything. It worked on mine and i have the same player.
remote control :
- Press "System Menu" key to enter Set Up menu.
- Move to "Preference Page" using arrow keys to the left or to the right.
- Press the following sequence in the remote control: 135566
- A menu indicating "Region Code" will appear.
- Change region using arrow keys to top or down. Region Code = 0 will play all regions.
- Press "System Menu" key to exit Set Up menu.
2answers
DVD player must be made region free by unlocking it.. after that you can play all the discs you want.. for ubnlocking it you can try google//
5helpful
6answers
Region Free Code: Philips DVP 5980
this worked perfectly, thank you!
3answers
Region codes
Philips DVP 3015K / DVP 3020 / DVP 3040 / DVP 3040K / DVP 5140 / DVP 5960
  1. Method 1:
  2. Open the disc tray
  3. Press SETUP
  4. Navigate to the preferences page
  5. Enter 138931
  6. Select the region using UP/DOWN
  7. Press PLAY
  1. Method 2:
  2. Open tray
  3. Press 9, 9, 9, 9, 0
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
