Adobe Premiere® Elements 3.0 Full Version for PC (718659982942) Logo
Anonymous Posted on Apr 15, 2009
Won't work with Vista 64 bit
I have just bought a computer running Vista 64 bit with core duo. My Premiere Elements 3 just makes the computer hang and the only solution is to turn off the power to regain control. I have set it to run as xp but it makes no difference. A friend runs the same program with vista 32 bit no problem.
  • Anonymous Apr 15, 2009
    Thanks I should have thought my purchase out a bit better
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 15, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
557
Points
Hello
I am running Windows Vista 64 bit also and finding out that there are a lot of programs that won't run on a 64 bit machine due to the fact they are not supported for 64 bit, listed below is info to your problem,
Photoshop Elements compatibility with Windows Vista This TechNote lists which versions of Adobe Photoshop Elements are compatible with Microsoft Windows Vista.
Photoshop Elements Version Compatible with Windows Vista (32-bit)? 6.0 Yes 5.0 Yes
Note: You must download the Photoshop Elements 5.0.2 update to ensure compatibility with Windows Vista.
4.0 No 3.0 No 2.0 No 1.0 No
Note: For the versions of Photoshop Elements that are compatible with Windows Vista, the 64-bit editions of Vista are not supported. Adobe Technical Support can assist you with the features of Photoshop Elements and with issues that also occur in supported operating systems. Technical Support cannot, however, assist you with issues that occur only on the 64-bit editions of Windows Vista. Instead, you can use the following support options on the Adobe website:
  • The User to User Forums, on which you can enter your problem or concern to see if another Adobe user can offer advice. Access this resource at www.adobeforums.com.
  • The Support Knowledgebase, which contains solutions for issues that occur on supported operating systems. Access this resource at www.adobe.com/support/photoshopelements.
dmg49
I added ram but it only recognized half of it
You need to go look at your computer specifications to make sure if can accept it, then make sure if over 3 GB you are running 64 bit windows
Base system drivers
Card reader drivers, get it either from HP or Windows update. If you are running Windows 7, use the vista drivers. Just make sure if you are running 7 64, use vista 64 or 7 32 bit, use vista 32.
https://support.hp.com/us-en/drivers/selfservice/hp-pavilion-dv9900-entertainment-notebook-pc-series/3725216/model/3747256
Look under storage section. Ricoh download and install. This for using SD cards from cameras to pull up pictures you have taken or any other files on it
Why is my computer still lagging even after I close the game
Sounds like there is some process being run that is eating up a lot of your RAM. One thing to check is that you are using a 64-bit install of windows if you are using 32-bit it won't matter that you have 6gb as you can only use 3gb with it. It could be that you are running 32-bit and 7 is taking up about a gb of RAM while the games (even when closing) take up 2gb or so. So you could be maxing your 3gb on 32-bit.
2helpful
97F81AF1-0E47-DC99-A01F-C8B3B9A1E18E} HRESULT: 0 X 800736B3 is my problem. i wont install office plus 2010
check and make sure both windows Vista and office plus 2010 are both 32-bit system. If your windows vista is 32-bit and your office plus 2010 is 64-bit then the office won't install.
this is how your check if your computer is a 32-bit or 64-bit system
1. click start
2. look for my computer
3. right-click my computer
4. click PROPERTIES
5. from the properties window you will see if your vista is a 32 bit or 64 bit operating system.
for your MS OFFICE plus 2010 brows the cd and to determine if your office is a 32 bit or 64 bit
1. you should see x86= this is a 32 bit
2. x64 = this is a 64 bit
1helpful
Can the Dell Latitude D610 run any of the following games: Age of Conan Star Trek Online Champions Online Aion
Check your system if it meets the following requirements
Age of Conan
Required
OS: Windows Vista/XP
Processor: 3GHz Pentium IV
RAM: 1GB RAM
Video Card: Shader Model 2.0 and 128MB RAM: NVIDIA GeForce 5800 or ATI 9800
Recommended
Processor: Intel Core 2 Duo 2.4 GHz (E6600) or better
Video Card: NVIDIA GeForce 7950GX2 or better
RAM: 2GB or more
Enhanced for: DirectX 10, 64-bit processors, multi-core
Supports Parental Controls on Windows Vista
Start Trek
System Requirements
  • OS: Windows XP SP2 / Windows Vista / Windows 7 (32 or 64-bit)
  • CPU: Intel Core 2 Duo 1.8 Ghz or AMD Athlon X2 3800+
  • Memory: 1GB RAM
  • Video: NVIDIA GeForce 7950 / ATI Radeon X1800 / Intel HD Graphics
  • Sound: DirectX 9.0c Compatible Soundcard
  • DirectX: Version 9.0c or Higher
  • HDD: 8GB Free Disk Space
  • Network: Internet Broadband Connection Required
  • Disc: 6X DVD-ROM
Recommended System Configuration
  • CPU: Intel E8400 Core 2 Duo or AMD Athlon X2 5600+
  • Memory: 2GB RAM+
  • Video: NVIDIA GeForce 8800 / ATI Radeon HD 3850+
  • Disc: 6X DVD-ROM
To check your system hardware> click on start>all programs>accessories>system tools> system information.
Thanks for using Fixya
proton
32 bit operating system
well in laymen terms nowadays 64 bit is newer tecnlogy and 64 bits one process 64 units of data at a time as compared to 32 bit OS.
64 bit is in core 2 Duo and later systems..
64 bit OS provide full support to the 64 bit architecture thus gaining the overall efficiency.
1helpful
2answers
Error loading C:\program~1\Mywebs~1\bar\1.bin\m3plugin.dll
The error is related to the myWebs search bar. Click on start >> Run >> Type Msconfig and open the sytsem configuration utility. Go to the startup tab and look for an entry related to Mywebs and uncheck it. Click apply and Ok and restart the system
Rate if useful.
3helpful
3answers
Diffrence
The terms 32-bit and 64-bit refer to the way a computer's processor (also called a CPU), handles information. The 64-bit version of Windows handles large amounts of random access memory (RAM) more effectively than a 32-bit system. For more details, go to A description of the differences between 32-bit versions of Windows Vista and 64-bit versions of Windows Vista online.
32 bit IE won't connect to internet in Vista 64 bit.
32 bit programs, last I checked, won't work in a 64 bit operating system, just as 64 bit won't work in 32 bit operating systems.
If 32 bit programs will work in a 64 bit OS, they probably won't work properly.
Windows vista
Appreciate the direct "Ask me" again and likewise the previous ratings.
To my knowledge, Vista x64 is just an x32 with 64 bit addressing. Some have reported that 64 bit on a Core 2 Duo isn't a very good idea with the extra speed gain of x64 over x86 being marginal for now. Offhand, you might be better off still with X32 at least for the time being.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Top Adobe Computers & Internet Experts
k24674
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
