SanDisk Sansa Fuze MP3 Player Logo
A
Anonymous Posted on Sep 10, 2013
I dropped my sansa fuze - SanDisk Sansa Fuze MP3 Player
Why wont this sync with my itunes library?
Hi, Is the SanDisk Sansa Fuze compatible with iTunes? In some ways, it is. Unfortunately, the Sansa Fuze and iTunes don't always play nice together. You'll have to get a few workarounds to make these two sync together.
The SanDisk Sansa Fuze and iTunes
The SanDisk Sansa Fuze is natively a Windows product. You should be able to sync it with Windows Media Player automatically. However, not everyone owns a Windows PC and even if they do, they might store more music in their iTunes library.
If this is the case for you, you might find it helpful to be able to sync your Sansa Fuze with your iTunes music library. Bear in mind that you won't be able to sync apps, games or any other iTunes products that are not formatted for use on a Sansa Fuze.
Using iTunes with the Sansa Fuze
So, is the SanDisk Sansa Fuze compatible with iTunes? If you download the right software, it is. Apple offers a free download that works with many other non-iPod MP3 players, Sansa Fuze included.
Unfortunately, this product only runs on a Mac operating system. However, if you own a Mac, this is great news because it means you can still use your Fuze without buying a Windows PC.
If you use a Windows PC and want to transfer your iTunes music to the Fuze, don't lose hope - there's a way to do that, too.
Syncing the Sansa Fuze with iTunes
If you're using a Mac, visit this link for Apple's free software download. It comes directly from Apple, so you can be assured that it's spyware-free.
Install the software on your Mac. You need Mac OS X 10.4 or higher as well as iTunes version 8 or higher.
Plug your Sansa Fuze into the Mac and wait for the software to open. You should see a listing of your iTunes music library pop open in a window. You're then given the option to sync as many songs as possible onto your Fuze.
The syncing process is similar to syncing an iPod. Don't unplug the device until it's finished.
Syncing the iTunes Library in Windows
You can sync your Sansa Fuze with iTunes using a script called the Automator, found here. Once downloaded, open the script under your "Downloads" folder on your "C:" drive and find a string of characters that looks like this: "/Users/richard/Music/*.mp3".
Replace the name "Richard" with your own username. Don't change anything else. Select "File," "Save" from the menu.
Select the Automator icon with the right click button on your mouse and choose "Open with," "Automator Runner." If working properly, this should automatically sync the music from iTunes with your Sansa Fuze.
If that doesn't work, go into your iTunes library and highlight any DRM-protected tracks that you purchased from iTunes. Right-click and select "Make MP3 Version." These should now be compatible with the Automator.
This sounds like more or less of a "hack" than a solution, but this might be the only way to sync music from iTunes to your Fuze using Windows. If all else fails, make MP3 versions of the songs as shown above, then navigate to your iTunes folder where those files are stored. Then drag and drop these into Windows Media Player, where they should sync right onto your Fuze.
Hope that helps..
3helpful
2answers
My computer isnt reading the sansa fuze
On your Fuze, go to the "Settings" menu, then the "USB Mode" item, and set it to "MSC".
Try again. If it still doesn't show up, make sure the USB cable isn't damaged, and connect it to a USB port on the BACK panel of your computer.
If that doesn't work, try it on a different computer.
Sansa Fuze went dead after charging; dropped about 18'' onto carpet earlier, but saw no problem until after charging.
sansa fuze mp3 players are notoriously pieces of ****. they malfunction randomly, and most of the time, unfortunately, cannot be fixed. i have experienced this first hand. even though it's actually a problem with their software, or the hardware in it. my advice is seek third party repair help.
1helpful
I don't know how to get music onto my Sansa Fuze.
There's a Sandisk support site for the Sansa Fuze, see:
http://kb.sandisk.com/app/answers/detail/a_id/3249/
Sansa Fuze user manual in pdf format:
http://mp3support.sandisk.com/sansa/UserManual/FUZE/fuze_userguide_en.pdf
Important
There are 2 ways the Fuze can be connected to a computer to transfer
music: MTP mode or MSC mode, read page 16 (=13) of the manual.
The player can be set to automatic detection of the connection mode
or can be set to either one of the available connections.
MTP mode is used for transfers using software like Sansa Media Manager or Windows Media Player 11.
MSC mode is used for transfers using the "drag and drop" method in the computer's explorer.
Need more help ? Just post a comment.
Trying to import pictures from my library.When trying to open pix, get message-Unsupported Media Format- I have Sansa Fuze player.
I have the same player. I usually go to my computer, find the drive with the sansa, double-click to open the files.
Leave this window open,
Now go to your pictures, and open that file. Go to first top picture, right-click, this picture, then scroll to bottom of picture list, on last picture, press and hold shift key then left-click on the picture. Now all pictures should be high-lighted.
Now just drag the pictures over to the sansa pic file and drop them in there. THey should automatically add themselves to your sansa.
It should be JIF,BMP, and the other most common pic files.
Drag and drop any song or picture from your pc directly into sansa folder under my computer.
1helpful
I can't add videos to my Sansa FUZE.
first off get the arcsoft media converter 3, then drag and drop the videos you want to get on your mp3 player into the program, after it converts it it loads them onto your mp3 player as long as its connected, this program will also allow you to download youtube videos and put them on your mp3 player too. Your player supports WMA videos
Difference between the origional sansa and the sansa fuze?
the sansa fuze is the best to get because it is less prone to scrathes, glitches, problems with the screen,ect. the sansa fuze also comes with free rapsidy for roughly 15 days. the sansa e200 series has quite a few problems. the screen on mine is busted T_T, so i have to buy a fuze. My friend has a fuze and hes had i for 4 years. it still work great. just dont drop it from heights of over 40 feet and even then it will still probabilly work.
Best Of Luck Trying to find a sansa. P.S i wouldn't go with an ipod, they get brocken to easily trust me i would know.
2helpful
I can't see videos in my Sansa Fuze mp3 player
You need to use the Sansa Media Converter to convert videos (and photos) to a format the Sansa can handle.
Sansa fuze 4 g photos wont open
Get "Sansa Media Converter" from the Sansa website or the CD that came with you Fuze.
If you are not using the "Sansa Media Converter" program to convert the photos to a format the Fuze can display, they will not show up.
2answers
Sandisk Sansa
You go to the sansa website (google it) and download the sansa media converter for the sansa fuze. Install it and drag your movies into it and click convert. Long movies can take an hour on an average computer (be patient) and when it is complete unplug your sansa and make sure the video works.
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
