I was doing a load and a beeper sounded and it flashes F2. It is still in the Wash cycle
F02
Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and
F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4
minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is
running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
where is the drain pump filter
